headliner deck
LinkBack (1) Thread Tools
Old June 8th, 2008, 12:08 AM   1 links from elsewhere to this Post. Click to view. #1
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
headliner deck
anyone ever put a head unit in that spot on the headliner in between the visors?
SCT Mass Air Flow Sensor $200
Old June 8th, 2008, 12:47 AM   #2
Look Ma! My First Post!
2005 Mustang V6
auburn12 is on a distinguished road
why would you want to
Old June 8th, 2008, 01:33 AM   #3
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
move deck to the headliner and put in a touchscreen for a carpc in the old spot.
Old June 9th, 2008, 05:12 AM   #4
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
I can just imagine that ripping loose in a wreck. cant be good. but then show me a wreck that IS good...
Old June 9th, 2008, 09:20 PM   #5
1998 MUSTANG GT
EVILSIDER is on a distinguished road
Interesting idea....load pics if you do it..
Old June 10th, 2008, 12:09 AM   #6
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
yea im not really concerned about that...i mean it would ahve wires that would hold it, but if its a wreck that will the be the last thing i worry bout. i just would like to see some pics of this done if anyone has done it.
Old June 10th, 2008, 07:59 AM   #7
R3dFyre02's Avatar
sorry man, wires wont hold. at even 15 mils per hour people get killed by loose stuff in the car bouncing around. To many accidents I have responded to and seen people hurt and killed.
God luck and I hope you do more than just expect the wires to hold it.
Old June 10th, 2008, 04:59 PM   #8
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
obviously...im not gonna make it cheap...it will be secured in there however i decide to do it. most likely ima cut that hump that is there and do some fiberglass work and make somethin to put the metal sleeve in like the way it is now in its regular location
Old June 10th, 2008, 08:42 PM   #9
2004 Mustang V6
04DSGV6 is on a distinguished road
dude definitely update this if you do it. Sounds real cool
Originally Posted by 06RedfireGT View Post
The idea of smashing your face on it in an accident isn't so sexy.
Old June 10th, 2008, 10:51 PM   #10
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
i plan on it...just not this summer.
Old June 11th, 2008, 12:42 AM   #11
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
i did this for a dude in a van once. i found a bracket/housing for a single din head unit on the internet. couldn't tell you where i found it. this was about 5 years ago. but it looked absolutely retarded. he wanted it up high so i could cut out the dash and put in a 10" monitor. it worked, and the monitor looked good in the dash (thanks to lots of fiberglass work) but the head unit between the visors was about the stupidest thing ever. but, do what you like.
i have no mustang. so don't listen to anything i say.
Old June 11th, 2008, 02:42 AM   #12
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
what looked dumb about it...i mean that was in a van...there is a hump the headliner right now where it would go, i cant imagine it looking to bad. the plan is the put a 7 inch touchscreen in the dash. it should be an interesting install
Old June 11th, 2008, 05:16 AM   #13
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
his looked kinda silly cause he wouldn't let me form it into the headliner. i wanted to pull it out and make a fiberglass housing for the head unit that would blend into the head liner. then, recover with new fabric. giving it a factory look. he wanted to do it the cheap and "easy" way and use this plastic housing that i found for him. if you can make it blend into the headliner without just sticking out like a sore thumb, it should be pretty cool.
Old June 13th, 2008, 05:01 PM   #14
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
thas the plan...
Old June 14th, 2008, 05:33 PM   #15
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
should be pretty sweet.
be sure to do a write up and take some pics.
Old June 15th, 2008, 12:01 AM   #16
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
will do. im thinkin this will be next summers project along with putting the computer in my car since this summer kinda got takin by my turbo and new rear seat delete
Old June 15th, 2008, 03:55 AM   #17
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
cool. that'll give you plenty of time to map a out a good game plan. you don't just jump into something like that. without patience and a solid plan of attack, you could end up with a serious eye sore in a very noticeable spot.
and yeah, i'd definitely say that stereo work should play second fiddle to a turbo.
Old June 15th, 2008, 11:18 PM   #18
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
yea i usually sit down and draw it all out how i want to do any project. i got a whole notebook full of stuff. i figure it cant be too hard, its a matter of cutting out the area for the deck. then fitting and seeing what needs to be fabricated...then do the whole fabrication process and get it fitted. i probably going to have to rewrap the headliner. then i will just extend the wiring. sounds pretty easy but def. a time consuming process.
o yea def. the turbo takes front seat to everything haha. i didnt even know the turbo project was gonna happen this summer till like a week b4 it otherwise i would have an more free time.
Old June 20th, 2008, 10:32 AM   #19
gtredfire03's Avatar
2003 Mustang GT
gtredfire03 is on a distinguished road
Best Buy carrys a "under dash shroud" it about 20 bucks and that will give you some what of a starting point for mounting. The shroud isnt it very pretty looking but some fiberglass work to it will help it out.
Old June 20th, 2008, 05:28 PM   #20
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
ill check that out...thanks
LinkBack to this Thread: http://www.moddedmustangs.com/forums/audio-video/74783-headliner-deck.html
headliner deck This thread Refback June 8th, 2008 03:11 AM
Threads Similar to: headliner deck
How to remove headliner? tribaltek 2005 - 2010 5 May 20th, 2008 11:12 AM
headliner question BWAL 5.0 Mustangs 6 March 1st, 2008 01:58 AM
Headliner nero V6 Mustangs 11 September 7th, 2007 09:34 PM
Convertible Headliner Red87DropTop 5.0 Mustangs 1 January 11th, 2007 10:50 AM
Headliner Replacement cliff Classic Mustangs 14 November 20th, 2006 09:11 PM
