1pc Projector Head Lights installation
Hi guys,
Does any one know how to install 1pc projector head lights for mustang 94-98? I installed it already however there are 2 open wires(2 red and 2 blacks each sides) that come with these haed lights. I don't know what to do with these wires. What are these wires for? Thanks guys. ILoveMustang. |
does your new headlights have halos?
1998 Mustang GT Super Charged! CGS Sub frames, Auto Meter gauges, Bassani Exhaust! |
yes it does.
well, the other wires, MIGHT be for the halos, i should be getting mine in soon, so maybe i can help when i put mine on!
I'm thinkin about getting some halo's for mine, where did you buy them from?
yeah boyb1917 where did you buy your lights from?
one is probably for the halo ring/s. and the other set of wires for the 3 or so led's that it probably also has. you can wire em into the +12v thats on when your parking lamps are on. just tie it into the one on the back of the turn signal harness. also some people suggested possibly adding a switch to the halos/leds cause they get dim after awhile if left on all the time. dont know if thats the case. just what ive heard.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
yeah, i know for a fact that those are the halo's & the LED's on the lights.. i hooked all of them to a switch so that way i can flip em on & off whenever i so feel like it.. i also heard that they will burn out quick if hooked directly to the headlights so that was another reason i hooked em to a switch..
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
i have had mine for over a year and they are just as bright. i have them hooked up with the running lights.
i have the older version of the lights with only 1 halo ring and a small light on the inside instead of led's
#10 | |
the set of wires underneath the "projector" or outside bulb are for the halo... the wires near the inboard side (closest to the grill) are the lights for the inner light or LED's..... Wire them into the running lights is easiest
I just got my halo-projectors today. JDM with DOT approved amber sides $78 for set.
I have taken out the old lights but found the projector needs some trimming on the cars plactic back to fit. (tomorrows work) My four extra wires are for one set halo, one set for the little spot bulb, never was sure on what it does but will hook it to running lights. As for the halos I want to leave then on at night so am looking for a night sensor that will let them come on automatically when dark. They are low current draw so should not affect a good working battery. My surprise was I thought the projectors were the high beams. Also had a set of amber 1157s but they are not the proper type for side turn/running so had to buy a new set. Biggest issue after installing these is how to change bulbs with out having to remove whole unit. |
#12 | |
nice but thats not to bright in my eyes do they use the 9007`s or what ever it is? |
Threads Similar to: 1pc Projector Head Lights installation
| PROJECTOR HEAD LIGHTS INSTALL!!! | 04gt | 99-04 | 7 | October 10th, 2007 10:14 PM |
| Angel eye/projector lights | SilverStang06 | Visual | 1 | March 4th, 2007 10:13 PM |
| hid projector lights | droppedbass87 | Visual | 13 | January 3rd, 2007 05:19 AM |
| Projector head lights | scubasteve041186 | V6 Mustangs | 12 | December 26th, 2006 11:36 PM |
| 1pc Projector Head Lights! | jerb43 | Audio/Video | 13 | November 7th, 2006 11:29 AM |
