Charging Problem... Please Help!
Old November 11th, 2006, 06:02 PM   #1
cstmp8r is on a distinguished road
I recently bought a 89 lx with the 2.3. While driving the battery went dead and killed the motor. I put in a new battery and an alternator and it still does it. When at rest the volts read 12.49 and after starting it it reads 11.8 or so while idleing. Any ideas here? Thanks in advance
Old November 12th, 2006, 07:15 AM   #2
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
So it still dies when you are driving?
If so I think it could be a selenoid issue...
I would go to Autozone and have them test your Charging System...I think they still do that...
Facebook
Google+
Old November 13th, 2006, 01:17 AM   #3
I will look into that. Also I have not driven it. But I tested it in the garage with a dig. volt meter. I know that when the car is running it should be in the 14 volt range give or take but the voltage actually drops when running like there is a big draw on the battery (even when all acc. are off)) I have checked fuses, fusable links and wires but I'll be damned if I can see anything
Old November 13th, 2006, 01:47 AM   #4
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
If the voltage drops when the car is runnig then you have an altenator or a selenoid issue...Maybe your wires are not connected correctly on the starter selenoid...It should be up on the driver side of the engine bay at top of the fender-well...
Facebook
Google+
Threads Similar to: Charging Problem... Please Help!
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
charging help! pnyboi 5.0 Mustangs 3 May 7th, 2007 06:54 PM
is this a problem? Random-Hero V6 Mustangs 8 May 3rd, 2007 11:12 PM
UD Pulleys Rob Charging System? Finegan 2005 - 2010 4 April 17th, 2007 01:16 PM
Charging problem or battery shadowgames81 5.0 Mustangs 12 January 13th, 2007 02:34 PM
