![]() iTrader: 3 reviews
Bi Xenon HID lights
Ok I just finished installing my Bi Xenon bulbs using americanmuscles kit the lights work fine but when I hit the high beams the lights shut off instead of turning the high beams on I can't see how I installed anything incorrectly everything plugs into each other, the two grounds and then the power to the battery any one know whats going on maybe its the bulbs>?
![]() iTrader: 1 reviews
are you sure its a bi-xenon? look at the plug that goes into the drivers side headlight plug, if theres only 2 prongs instead of 3 (on the hid side, not vehicle side) then its only one beam
my old hid kit did that, high beams were just the regular beam and low beams were nothing, so i switched them around, the new kit i got works fine though both beams, so check the plug first.
#3 | |
RLY SRS
i bought the dual beam one from AM. works fine except the fact that i needed to unplug my daytime running lights because they kept shorting out my hid's and blowing the ballasts.
im thinking about buying a kit from stealth auto though because their ballasts are like half the size
yea they are definitely Bi haha, My positive wire going to the battery needs a better connection I was messing with it yesterday the black grounds work with the low beams and the red positive wire works with the high beams! problem solved.
Threads Similar to: Bi Xenon HID lights
| bi-xenon HID headlights- high/low beam question | LilPoni11 | Visual | 43 | January 8th, 2009 02:06 AM |
| HID lights | gooberhead320 | V6 Mustangs | 8 | July 22nd, 2007 11:30 PM |
| fake "hid" xenon lights | 232stang | The Clubhouse | 24 | June 25th, 2007 12:06 AM |
