Look Ma! My First Post!
Help! I Busted My Stereo
I took out the factory stereo in my 2000 mustang today, to put in an after market one I pulled from my old ride.
The wires matched perfectly, but when I pluged it all in, it didn't work. Then, when I pulled it back out and put the OEM radio in, it doesn't work either. Is there some sort of anti-theft device at work here that I don't know about? How do I fix this? |
if the head unit dont turn on it might be a bad ground....but if ur radio doesnt work know check ur fuses...happens to me alot i think i went through at least a dozen fuses puttin my stereo together
they use a big ground cable not in the harness so it can be hard to mis but easy to forget.what was the other head unit? is this mach360?I know a bit on the 2000 as I have one I will make a post sometime on pictures of the stereo install
#4 | |
deffinatly the fuse. check ur manuals to see which fuse it is, althought im pretty sure its 27?
Threads Similar to: Help! I Busted My Stereo
| Checking manuelly for a busted abs sensor? | sorrowfulkiller | 96-98 | 15 | June 2nd, 2007 10:06 AM |
| My Door Is Busted | TheTechnical99 | V6 Mustangs | 3 | September 6th, 2006 03:44 PM |
| finally busted out the camera to learn how to use it. | JRuckas | Multimedia | 13 | June 6th, 2006 01:11 PM |
