Remove Mach 460 Headunit (2001)
Old July 17th, 2008, 10:49 PM   #1
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
How the crap do you get this damn thing out? POS ate CD's so I have to take it out and pull it apart and all the fun stuff.
Old July 17th, 2008, 11:04 PM   #2
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
should be holes to the sides that fit the keys for it (or close hangers). if thats not right then it might just have screws behind the plastic cover of the console...its not hard to figure out once u pull that piece off.
SCT Mass Air Flow Sensor $200
Old July 19th, 2008, 04:42 AM   #3
drgnracins bitch
baron's Avatar
92 Mustang LX
baron is an unknown quantity at this point
first pop the shifter bezel off
then the bezel that goes around the ac controls, top center vents, and the radio
there are two 7mm bolts holding the radio in...
take those off and pull STRAIGHT out.. there is a brace back there that you can brake if you are not careful..
Threads Similar to: Remove Mach 460 Headunit (2001)
remove mach 460 yojoe600 99-04 8 March 1st, 2008 08:38 PM
Headunit swap (mach 460) Reset Audio/Video 24 September 12th, 2007 06:23 PM
2001 mach 460 mannysoccer15 Audio/Video 0 April 15th, 2007 11:10 PM
