Installing an aftermarket radio
LinkBack (1) Thread Tools
Old July 20th, 2008, 05:34 PM   1 links from elsewhere to this Post. Click to view. #1
BostonPerformance's Avatar
99 Cherokee sport/87 5.0
not tested
BostonPerformance is a jewel in the roughBostonPerformance is a jewel in the roughBostonPerformance is a jewel in the rough
I recently had the head unit stolen out of my car, and had to replace it on an extremely tight budget. I don't have any sort of aftermarket speakers or amps, other than the factory amplifier the mustang came with and a cheap pioneer head unit (stolen). I got a Jensen head unit from circuit city for $80. I was very satisfied with the price, and the performance of the unit so far. These instructions are for the install of a replacement head unit, not for an upgrade (although my new radio is far better than my old one..)
On my mustang, there were three wires unplugged from the stolen radio.
a simple metal plug, this is your antenna.
a rectangular grey plug with six wires feeding into it- these are your power wires.
a square grey plug with one thick grey wire feeding into it.
I was able to get a FORD ADAPTER KIT from Wal-Mart for Ten dollars. they are next to the radios, and are labeled by the manufacturer of the vehicle. Your radio should come with a plug which has 12 wires coming from the back of it. You simply pair the wires that came with the radio to the wires in the adapter kit, they should match completely. You will use both pieces (grey and black) that came with the adapter kit. I simply wrapped the ends of the wires around each other and taped them up- again, I was on a budget.
Once this is done, you plug the grey rectangular adapter to the six wired grey plug in your car, and the black plug with 8 wires on it (speaker wires) goes to a black plug that you will find plugged into another plug in your dash. to find this:
look into the empty radio bay. On the right, there are two rectangular plugs- one grey and one black. unplug the black one and plug your adapter into it. plug up the antenna and the wiring harness to your head unit, pop it in according to the product instructions, and you're good to go!
Credit goes to Wraitherlx for helping me on my install.
Here's some info he sent me:
Audio[color="Red"]
Battery GREEN/YELLOW (+) RADIO HARNESS
Accesory YELLOW/BLACK (+) RADIO HARNESS
Ground BLACK/GREEN (-) RADIO HARNESS
Illumination LIGHT BLUE/RED (+) RADIO HARNESS
Power Antenna AMP=DARK BLUE
Amp Turn On DARK BLUE (+) RADIO HARNESS
LF Speaker (+) ORANGE/LIGHT GREEN
LF Speaker (-) LIGHT BLUE/WHITE
RF Speaker (+) WHITE/LIGHT GREEN
RF Speaker (-) DARK GREEN/ORANGE
LR Speaker (+) GRAY/LIGHT BLUE
LR Speaker (-) TAN/YELLOW
RR Speaker (+) ORANGE/RED
RR Speaker (-) BROWN/PINK
Amp Location BELOW RADIO
Radio Security YES
Convenience
Headlights-Lo RED/YELLOW (+) AT LIGHT SWITCH
Wipers-Lo ORANGE (+) AT WIPER SWITCH
Trnk Release VIOLET/YELLOW (+) AT SWITCH OR DRIV KICK PANEL
Remote start
Battery YELLOW (+) IGNITION SWITCH HARNESS
Ignition 1 TAN/WHITE (+) IGNITION SWITCH HARNESS
Starter 1 WHITE/PINK (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/BLUE (+) OR GRY DRIVERS KICK LOW UNDER RUG
Trunk Trigger BLACK/PINK (+) LIGHT IN TRUNK
Hood Trigger N/A
Alarm Disarm DARK GREEN/PPL (-) DRIVER KICK PANEL
Parking Lights BROWN (+) DRIVER'S KICK PANEL
Security
Ignition 2 BLACK/GREEN (+) IGNITION SWITCH HARNESS(A.C.)
Ignition 3 GRAY/YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 GRAY/YELLOW (+) IGNITION SWITCH HARNESS
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript PATS
Key Sense BLACK/PINK (-) STEERING COLUMN HARNESS
Neutral Safety NOT GROUNDING
Tachometer TAN/YELLOW (-) COIL OR ORG/WHT PCM PASS KICK PANEL
Speed Sense GRAY/BLACK (AC) PASS KICK 104 PIN PLUG AT PCM POS 58
Brake Lights GREEN (+) BRAKE SWITCH OR RED/LT.GRN
Reverse Lights BLACK/PINK (+) HIGH PASS. KICK PANEL 8 PIN GRAY CONN
Horn YELLOW/GREEN (-) IGNITION SWITCH HARNESS
Power Unlock PINK/GREEN (-) NEGATIVE TRIG
PowerLock PINK/YELLOW (-) DRIVER'S KICK
LF Window Up LF:WHITE/BLACK )
RF Window Up RF:WHITE/YELLOW LR:GRAY/ORANGE RR:RED/BLACK
LR Window Up LF:YELLOW
RR Window Up RF:TAN/LIGHT BLUE LR:YELLOW/BLUE RR:YELLOW/BLACK
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander
Old July 20th, 2008, 07:02 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
great job on your install bro, if you or anyone else needs wiring information or help walking them through some stuff just PM me and I will answer as quickly as possible. Also, I have wiring info on "Just" about every car.
Old July 20th, 2008, 07:19 PM   #3
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
also, all the information I provide is strictly just to help you guys out. By no means am I saying that with this information you can go and troubleshoot or work on more advanced electrical systems. If you are trying to do something and are not sure on how please ask me or someone before trying to attempt it so that we can point you in the right direction ond/or walk you through it. Last thing I want you to do is totally screw up your car.
Old July 20th, 2008, 10:12 PM   #4
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
jensen....
SCT Mass Air Flow Sensor $200
Old August 19th, 2008, 05:10 PM   #5
KGrock85 is on a distinguished road
How do you remove the stock radio on a 07 mustang
Old August 19th, 2008, 09:52 PM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
if i remember right, side pieces pop off, center piece with CIG adapter pops off, center panel around shifter need to pop up a little so that you can remove the center radio bezel, then remove the screws for the radio there should be 4
dont quote me, its been awhile since i worked on one of the newer ones
Old August 24th, 2008, 08:44 PM   #7
wow ford has definately tried to make it a lot harder from there old two-prong pop out devices. thanks
Old May 3rd, 2010, 12:04 AM   #8
brandywine112972's Avatar
1997 mustang gt
brandywine112972 is on a distinguished road
is this the same wire color code on a 97 gt?
Old May 12th, 2010, 08:46 PM   #9
TheCrow13 is on a distinguished road
Thanks for the info
LinkBack to this Thread: http://www.moddedmustangs.com/forums/audio-video/81023-installing-aftermarket-radio.html
Installing an aftermarket radio This thread Refback July 21st, 2008 03:50 PM
Threads Similar to: Installing an aftermarket radio
ok aftermarket radio? Black02GT Audio/Video 9 May 14th, 2008 07:36 PM
Aftermarket Radio Issue 90Stang 2005 - 2010 0 March 4th, 2008 08:24 PM
Does Anyone No Anything About Aftermarket Radio/ Navigation? Ticket-Me-Yellow V6 Mustangs 3 December 21st, 2007 09:04 AM
aftermarket radio gooberhead320 Audio/Video 1 July 9th, 2007 03:29 PM
aftermarket radio gooberhead320 V6 Mustangs 1 July 9th, 2007 12:51 PM
