Any Way Around The Mach Audio System?
Old November 17th, 2006, 08:49 PM   #1
warriora66 is on a distinguished road
Hey guys i was wondering i have a 2003 v6 with a mach 460 audio system. most people say i have to replace everything if i want a new head unit or subs. has anyone heard of a way around this or will i have to get my car totally rewired and buy all new speakers?
Old November 17th, 2006, 08:51 PM   #2
mdvaldosta's Avatar
11.47@120.58
Not sure about the head unit (although you probably have to replace the amps if you do it, but I'm not sure) - however to add subs all you need is a line out converter to get the signal from the head unit, then run your amp and subs as you would any other setup. PS - moving this to the electronics forum for a better response.
Old November 17th, 2006, 11:58 PM   #3
320hpPony?'s Avatar
320hpPony? is on a distinguished road
Send a message via MSN to 320hpPony?
new head unit and re-wire the whole car....just upgrade the speakers to some efficient ones and add subs and u'll be jammin
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it!
Old November 18th, 2006, 01:31 AM   #4
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
You can add a new headunit and then just get the Mitre adapter so you can use the 460 with the aftermarket head-unit...
To run subs you are going to need to run new amps in the rear...You need to make sure you pick up a head-unit with pre-amp outputs...
Then you get an install kit from your local best buy or some place like that...Run the RCA Jacks, Power wire, And remote wire back to the trunk of the car...Also find a good place to attach a ground wire and run that to the amp too...Hook it all up to the amps...Then run the amps to the subs...Its pretty easy...And if you read the directions it will be no worry...
Facebook
Google+
Old November 18th, 2006, 01:51 AM   #5
what kind of line out converter do i need? there are several how many channels do i need. should i get a two or 4 channel? i work at best buy so i get things pretty cheap i just dont know what to get!
Old November 18th, 2006, 10:41 AM   #6
loudenough is on a distinguished road
Send a message via AIM to loudenough Send a message via MSN to loudenough
I think he ment Metra
http://www.metraonline.com/
http://www.metraonline.com/product_l...stang&type=ALL
Look for the 70-5511
PAC makes some nice items to let you use your stock head unit if you would like
http://www.pac-audio.com/
For running just 2 subs you need a mono or 2 ch amp that matches up with the subs you get.So if you get 2 4Ohm subs get a 2ohm stable mono amp or a 2 ch. and run one sub off each ch.
Old November 18th, 2006, 04:53 PM   #7
formgen is on a distinguished road
you want the metra 70-5521, it has RCA inputs for the two amps in the back. My AVIC-D2 runs the tweeters in front and rear, then it's sub preout is fed thru the metra harness to feed the woofers in the door and rear shelf.
Old November 18th, 2006, 04:55 PM   #8
map view
Old November 18th, 2006, 05:07 PM   #9
HERES WHAT IT LOOKS LIKE WHEN YOU PULL OUT THE MACH, 2 CONNECTORS, ONE FOR THE SUBS AND THE OTHER HAS YOUR TWEETERS, 12V, GROUND, VSS WIRE, AND ACC WIRE.
THIS PIC SHOWS THE SUB HARNESS OF THE METRA 70-5521 W/RCA INPUTS
Old November 18th, 2006, 05:08 PM   #10
HERES THE OTHER HALF OF THE HARNESS THAT COMES IN THE KIT
Old November 18th, 2006, 08:22 PM   #11
I think you ment outputs not inputs right?(well inputs(to the harness) from your head unit outputs)Any way you can tell me the pin outs on that part of the harness for the RCA`s?I hacked in to mine at the back and it lets in tons of noise
I only need
left RCA +
left RCA -
right RCA +
right RCA _
Use this as a ref for pins and I can finish it up and post it for all to see.If you want to find the rest of the pins out I am sure people can maybe use them to.(8 pins right I forget of the top of my head?)
Old November 19th, 2006, 01:20 AM   #12
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Yeah I meant Mitra...Sorry...
Mitre is one of the contracting companies I am sending my resume too...lol
Facebook
Google+
Old November 19th, 2006, 03:39 AM   #13
In that case you may want to get there name right its Metra
Mitra or Metra you got me confused I never heard of Mitra
Old November 19th, 2006, 04:34 AM   #14
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
I meant Metra...I got one of the letter wrong...Chill
NO "Mitre" is a govt contracting company...
I work with alot of them over at Langley AFB, VA
General Dynamics
SAIC
Mitre
Boos Allen
Lockheed Martin and other...
I was not talking about getting a job working for Metra...I work for the govt now and will work for the govt for prolly the rest of my life...Plus I dont think Metra would match the salary for the job I am going for anyways...
Back on subject though...
Use the adapters and you should be good to go...
Facebook
Google+
Old November 19th, 2006, 12:22 PM   #15
I`m chill just razzing you.Sorry I just had to giggle at it
Old November 19th, 2006, 05:59 PM   #16
I only need
left RCA +
left RCA -
right RCA +
right RCA _
If you zoom into the pic I posted you can see that the positive for left and right are the 2 pins on the far end. On your chart, 4 is positive left, 8 is positive right, negative is the pin directly to the left of those two pins. Pins 1 and 5 are the turn on leads for the 2 amps. Pins 2 and 6 are not used.
2004 DSG GT, D1SC w/12psi boost=441 RWHP/ 424 RWTQ
Old December 26th, 2006, 08:12 AM   #17
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Ok I need to know if this same harness will work with mny 2002 Mach 460 Set-up...
I want to make sure before I buy one...
Please be specific...
Thanks
Chris
Facebook
Google+
Old January 5th, 2007, 08:08 PM   #18
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
hey formgen where did you get the silver panels for the shifter and all that stuff? it looks really good!
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old January 22nd, 2007, 12:56 AM   #19
ForeverDreamin is on a distinguished road
Send a message via AIM to ForeverDreamin
Ok so if I also get this Metra thing will i have bass in the car again? lol..
Or should i take it back to Circuit City where they installed it and say do it right so i have friggin bass??
Old January 23rd, 2007, 04:47 PM   #20
cboog25 is on a distinguished road
Send a message via AIM to cboog25
Hey formgen what all did you have to do to get that head unit to work properly.. i already have subs ran with a line out converter with a stock head unit but i wondered how much of a hassle it would be if i wanted to get a new head unit. what kind do you have? cuz i am really liken it! lol
Chris
Threads Similar to: Any Way Around The Mach Audio System?
mach system help Blackbeauty v601 Audio/Video 9 September 24th, 2007 03:55 PM
mach 460 system QuEeNiEsTaNg V6 Mustangs 28 January 8th, 2007 04:07 AM
Mach Audio MustangMatt96GT Audio/Video 4 December 30th, 2006 08:50 PM
$200 On Audio System! LenchikUCLA V6 Mustangs 31 November 22nd, 2006 11:12 AM
