Mach 460
Old August 4th, 2008, 02:37 PM   #1
1993/2000 Mustang GT
Yet to be determined
fox4.6 is on a distinguished road
Send a message via MSN to fox4.6
Mach 460
Which would sound better in my car: The Stock Mach 460 head unit, or an aftermarket one? Also, how do you hook the wiring harness adapter into the wiring harness? Do you unplug the wires out of the stock amp?
Old August 4th, 2008, 03:56 PM   #2
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
I think if you just change your HU it's going to make it sound worse. The amps that come w/ the Mach system are specifically tuned to the output of the stock HU. If you change the HU, the levels to the amps might be different and cause the output to be worse. If you start changing more it'll be a different story but just changing HU will make it worse.
Old August 4th, 2008, 07:09 PM   #3
2008 Hammock Rodeo Champ
Squints's Avatar
2003 F-150 Lariat
FX4 Supercab
Squints has a spectacular aura aboutSquints has a spectacular aura about
Send a message via AIM to Squints
change it out. it'll sound better. just make sure you get a head unit with sufficient pre-outs. i.e. front, rear and sub pre-outs. you'll also want something that has adjustable pre-out levels so that you don't run into a situation where you're over driving the factory amps with too much signal. i've done it in several cars and never heard one that sounded worse. if it's done right with good components, it will sound good.
i have no mustang. so don't listen to anything i say.
Old August 5th, 2008, 06:29 AM   #4
Moderator
2003 Grand Cherokee
He said just changing the HU, nothing about getting good components (assuming you're talking about the speakers). Also, what's your definition of good...just louder? I've had tons of friends who think their system sounds "awesome" but it's just loud. Then when they come and listen to mine they are like...
Threads Similar to: Mach 460
mach 460 96gtponyred 96-98 25 September 13th, 2007 01:48 PM
Mach 460 HELP! pizon Audio/Video 16 August 13th, 2007 09:38 PM
Mach 460 Help bradg Audio/Video 2 June 18th, 2007 09:52 PM
Mach 460 Clayhistorian Audio/Video 10 April 11th, 2007 02:03 AM
Mach 460 mustangsweethrt00 Audio/Video 18 August 28th, 2006 04:38 PM
