Fashion Guru
where to plug in the amp!?
i got a new stereo today. it is a xdvd8265. i cant figure out where to plug the amp wires in. any help?
here is the back of the unit
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
Doesnt look very amp compatable to me...
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis |
2008 Mustang GT
depending on the amp, there should be a front and rear for a 4 channel amp and a subwoofer for a mono amp. This is assuming that you have 3 sets of preamp outs on your head unit.
99 Miata - FFS coldside supercharger (5psi), cobalt header, RS catted midpipe, borla muffler 89 LX 5.0 - BBk air intake, 75mm Maf, 70mm TB, TFS intake, GT40p heads, F303 Cam, 24lb injector, FPR, GT40p header, BBK O/R H, super 44 catback |
Fashion Guru
i have everything stock except the headunit
2008 Mustang GT
I would maybe try plugging the amp into the 5.1 channel outputs.....other than that i don't see where else the amp would plug into.
Fashion Guru
http://www.moddedmustangs.com/forums...p-harness.html
would the RCA adapter work? i know it says for 03+ and i have an 01 but is that what i should look for, but for my year? |
Fashion Guru
ok i went and picked this up
Parts Express:Metra 70-5519 Ford 2000-2001 Amplifier Integrator Plug all i needed was the one for the RCA. but i plugged it in and the amp still doesnt work. i tried plugging it into all the red and white points. do i need to tie those other wires that are attached to something? |
Moderator
are you trying to power up your factory mach or trying to add an aftermarket?
Moderator
that is a dual if im not mistaken, if you are trying to add an aftermarket then the BLUE set of RCA's are non-fading/Sub outputs, the GRAY set are the rear outputs, the BLUE are the front outputs, the YELLOW is AUDIO/VIDEO Input 1, the RED is AUDIO/VIDEO Input 2, and the GREEN is for REAR Camera input/Video output.
Moderator
if you are trying to power up the factory subs make sure that you connected the amp turn on wire from the car harness to radio harness. BLUE/WHITE, I think on the DUAL there is only a BLUE wire.
Fashion Guru
thanks a lot. that helped tremedously. i think. i connected the two blue wires. but havent turned it on cause i dont know where to ground the black wire. do i put it somewhere or just let it sit there not attached to anything?
Fashion Guru
the front two subs in the door wont work but the rest do
Fashion Guru
nevermind i got it all figured out now. i had to wire both blue/white wires into the solid blue one in the power harness
Moderator
yeah the solid blue wires are for power antenna, which we dont have on our cars glad you got it working though
2003 Mustang GT
On the daul radios they do not have a power ant wire, it is just a blue and that is the amp turn on. Daul doesnt use the blue/white like everyone else the the industry, they just color it blue.
#16 | |
Fashion Guru
do i need to ground the wires to metal? |
Moderator
what wires?
Fashion Guru
there are two wires from the amp harness that say ground on them. they are gray i think
Moderator
yeah, I think there is a black/white wire which is the amp ground wire. anything that says ground on it just tap them into the black wire from the harness
Threads Similar to: where to plug in the amp!?
| Champion Spark Plug 7989 Double Platinum Plug | UNVMYGT | 2005 - 2010 | 6 | November 24th, 2011 01:50 AM |
| Pulse Plug vs. Spark Plug | BlckBullitt01 | 99-04 | 4 | May 18th, 2008 02:51 AM |
| 2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec | ozan169 | 2005 - 2010 | 4 | February 7th, 2007 09:03 PM |
| Eliminate Both EGR & Check-Engine Light With This Plug | Zak | 5.0 Mustangs | 5 | October 13th, 2006 11:22 PM |
