Aftermarket car alarm - Page 3
LinkBack (1) Thread Tools
Old November 10th, 2008, 10:10 AM   #41
2007 Mustang GT
registo is on a distinguished road
Hello,
I did the install yesterday, but doors don't lock or unlock with the viper remote.
I wired like the diagram for "Three wire (-) ground pulse controlling factory lock relay". Is it the good one for Mustang ?
How can I check ?
Thank you
Regis
2007 Mustang GT - Flexfuel - Steeda CAI - Xcal3 - Tokiko D-Spec - Steeda springs
My videos on YouTube (serach registo77 )
http://www.youtube.com/watch?v=zbIxAMjV6OE
Old November 10th, 2008, 10:24 AM   #42
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
are you just using the lock harness that just has the blue and green wires on it or are you using the the 3 wire relay pack that has a red, blue, and green wire; then it goes into a black relay that has 5 or 6 wire coming out of it?
Old November 10th, 2008, 12:10 PM   #43
2007 Mustang GT
Yes, i used only the door lock harness, with
- green/black -> White/violet In Black 26-pin plug
- blue black to Dk.blue/green In Black 26-pin plug
Am I wrong ?
Do I have to connect on FACTORY ARM and DISARM ?
( maybe i didn't understand what is the lock/unlock )
Old November 10th, 2008, 12:17 PM   #44
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
ok, so you are using the relay pack. There should also be a violet/black or purple/black wire/wires on there what do you have those hooked up to?
Old November 10th, 2008, 12:20 PM   #45
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
this wire need to be hooked up to ground since you door locks are negative trigger. what this does is it converts the ouput to the lock and unlock wire to negative enabling the locks/unlocks to function
Old November 10th, 2008, 12:22 PM   #46
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
the other wires that you hooked up are correct though, you just need to ground out that wire that i mentioned.
Old November 10th, 2008, 12:58 PM   #47
2007 Mustang GT
I grounded the violet/black and violet ( on the same wire with fuse ).
Maybe I can do some tests..
Old November 10th, 2008, 01:32 PM   #48
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
you grounded it and still got nothing or did it work? also make sure that you got a good ground, dont use anything that already has wires going to it. take your drill or whatever scrape some paint off and get your own ground. If it still doesnt work if you can take some pics of your lock/unlock connections along with the wires from the unit I can tell if something was missed or not.
Old November 10th, 2008, 02:17 PM   #49
2007 Mustang GT
Ok I ll do it. I grounded the alarm ground and the 'lock harness ground' on an existing gound ( the goung at the right of SJB )... I ll modify it.
Old November 10th, 2008, 02:29 PM   #50
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
so i take it that you still didnt manage to get the locks to work? when you hit unlock do you hear anything? you should hear 1 audible click coming from the "brain" when you hit lock and 2 audible clicks when you hit unlock.
Old November 10th, 2008, 02:50 PM   #51
2007 Mustang GT
yes I hear the click ( inbeded relay ) . I ll test connectivity between wire (violet and black violet ) and real ground.
Old November 10th, 2008, 06:42 PM   #52
2007 Mustang GT
For your information, I didn't wired the following wires:
H1/7 : instant trigger
H1/9 : Domelight relay output
H1/10 : Channel 3 output
H1/12 : Ground when armed ouput
H2/1 : Second unlock
H2/3 : Retained accessory output
H2/4-5-6 : Channel ouputs
H2/8 : Factory disarm output
H3/A : Domelight relay input
H3/B : Lock normaly closed
H3/E : Unlock normaly closed
I m not sure for H2/1 and H2/8.
Auxiliary and Door lock harness are very short. So the only place I found for the CPU is on the SJB.
I didn't connect the Immobilizer yet. Wires are extremly short too and I ll need to add wire to go to ignition switch harness ( if it is the good place to connect ).
Old November 10th, 2008, 07:04 PM   #53
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
sounds like you got everything. those wires that you listed you are not going to need. so are you still not getting any lock or unlock? Just to check you sure you got it plugged into the right spot, cause some of those plugs are the same and it can get you mixed up. yeah, easiest thing to do is to just extend the wires so that you can reach everything that you need.
BUILD 2 IN PROGRESS
Old November 10th, 2008, 07:14 PM   #54
mustangFRANK01's Avatar
mustangFRANK01 is on a distinguished road
now wires needed
hahaha
"I said wheres the love"
--US Army Cavalry--
"Cav Scouts: First ones in, last ones out"
Old November 10th, 2008, 07:16 PM   #55
2007 Mustang GT
It is the night in France at now, I ll check ground tomorrow
TY for your help! I ll let you know if it is OK
Old November 11th, 2008, 12:53 PM   #56
2007 Mustang GT
I m comfused : I did an error. I wired factory alarm arm and disarm in place of Power lock/unlock !
I will reconnect good wires in the next days.
Last question : how to connect trunk pin ?
there is a white yellow (+) wire ( SJB blk 26 pin plug / pin 15 ) but on the alarm, there is an instant trigger input ( blue wire ) with polarity (-).
Old November 11th, 2008, 08:10 PM   #57
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
you will need a relay in order to change the polarity output. good to see that you found your error, best way to learn is to mess up. if you can manage to get a hold of a relay then I can tell you how to wire it up.
BUILD 2 IN PROGRESS
Old November 12th, 2008, 02:44 AM   #58
2007 Mustang GT
I know what is a relay but I nerver used one in a car. I m ok for information about what relay and how to wire it.
Thank you
Old November 12th, 2008, 11:40 AM   #59
2007 Mustang GT
Door locking/unlocking with viper remote works !
Last things to do :
- connecting trunk pin
- finding the place to fix the siren and the CPU. I think the siren must be under the hood, but I need a place not too HOT ! Concerning the CPU, I ll try to fix it close to the SJB.
Old November 12th, 2008, 01:40 PM   #60
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
good to hear that you got it working. when you get the relay just let me know. also that Blue instant trigger wire you are not gonna use unless your car has a switch on it. What it does is if someone breaks into your trunk it sets off an "instant trigger". The wire that you will be using is the Red/White wire, if i remeber right it is 2nd auxillary output.
BUILD 2 IN PROGRESS
LinkBack to this Thread: http://www.moddedmustangs.com/forums/audio-video/87630-aftermarket-car-alarm.html
Aftermarket car alarm - Page 4 This thread Refback November 21st, 2008 03:15 AM
Threads Similar to: Aftermarket car alarm
Car Alarm Freaking Our help Blackbeauty v601 Audio/Video 14 September 3rd, 2008 02:05 PM
2-way FM car alarm medic_chris85 Audio/Video 8 August 24th, 2008 05:23 PM
Car Alarm Sunshine V6 Mustangs 6 January 8th, 2008 03:51 AM
Is this alarm system aftermarket on a 98 gt? Blue98GT Modular Mustangs 1 December 20th, 2007 07:12 PM
Car alarm locknest Audio/Video 5 February 18th, 2007 11:52 PM
