Aftermarket car alarm - Page 4
LinkBack (1) Thread Tools
Old November 12th, 2008, 05:16 PM   1 links from elsewhere to this Post. Click to view. #61
2007 Mustang GT
registo is on a distinguished road
the red/white is used to release trunk.
Do you have a example of relay to use? I don't know which one.
2007 Mustang GT - Flexfuel - Steeda CAI - Xcal3 - Tokiko D-Spec - Steeda springs
My videos on YouTube (serach registo77 )
http://www.youtube.com/watch?v=zbIxAMjV6OE
Old November 12th, 2008, 07:14 PM   #62
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
here is an example of one. When you order one make sure that it is a SPDT (Single Pole Double Throw) relay rated to at least 30 amps.
Buy the Metra 30/40 Amp Relay with 5-wire Locking Socket and other Car security installation parts at circuitcity.com
BUILD 2 IN PROGRESS
Old November 19th, 2008, 05:39 PM   #63
2007 Mustang GT
I ll reveive the relay in the following week.
I noticed that door trigger is the domelight circuit. So when I close the door and arm the system, the domelight is still on for few seconds and the system flashes 3 times, meaning zone 3 active ( door open ).
Is there anything better to do, to manage this input correctly?
Old November 19th, 2008, 11:06 PM   #64
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
what you will need to do is to program the "Bypass Notification" in the menu's section to off. It is factory set to on.
BUILD 2 IN PROGRESS
Old November 19th, 2008, 11:09 PM   #65
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
if you need help on how to program it let me know. there are sequences that you have to go through using the valet switch.
BUILD 2 IN PROGRESS
Old November 20th, 2008, 05:45 PM   #66
2007 Mustang GT
No problem with the valet switch, it works
Maybe a stupid question, but where is the better place to fix the control unit?
I think to install it near the SJB but there is not so much place!
Same for siren, I have to find a place not too HOT under the hood.
Any idea?
TY
Old November 20th, 2008, 09:22 PM   #67
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
i usually hide the box underneath the dash (steering column) but just try to hide it somewhere out of site (but easily accessible for you if need be in the future) ZIP TIES are your best friend in this instance. As far as the siren just afix it to someplace by the firewall best way is to screw it somewhere on the firewall or just zip tie it to some wires, cant remember where I usually put it cause i do soooooo many of them. as long as its not sitting on top of the engine or the exhaust manifolds you will be fine. so you were able to program the "Bypass notification" right? Good job man.
BUILD 2 IN PROGRESS
Old November 21st, 2008, 01:51 AM   #68
2007 Mustang GT
Yes, I was able to do it
Thanks again .
Now I feel comfortable with the alarm and without all your informations and tips, I still be lost
Old November 21st, 2008, 10:39 PM   #69
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
cool, just let me know when you get your relay in and then ill help you from there.
BUILD 2 IN PROGRESS
Old November 27th, 2008, 11:24 AM   #70
2007 Mustang GT
I received them.
I think I have to cut the trunk pin wire , to connect it on 85 and 86.
Then, I connect the instant trigger to 87. And the last one is the 30.
To the ground ?
Old November 28th, 2008, 10:47 PM   #71
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
no, you will connect the red/white wire to 85 and 86 to 12 volt CONSTANT, 87 will go to ground, and then 30 you will take that wire coming off of the relay and tap that directly into your trunk release wire.
BUILD 2 IN PROGRESS
Old November 28th, 2008, 10:48 PM   #72
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
is the red/white wire a negative (i think just cant remember) or positive trigger output?
BUILD 2 IN PROGRESS
Old November 29th, 2008, 04:35 PM   #73
2007 Mustang GT
the trunk pin is the white/yellow positive.
the instant input trigger on Viper is negative.
Which red/white do you talk about?
Old November 30th, 2008, 08:51 PM   #74
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
you are talking about the BLUE instant input trigger. what that is used for is for the trunk/hood switch that lets the alarm system know that the trunk/hood is open and to send an "instant trigger" to set off the alarm. the red/white wire is and auxillary output that will send a negative/positive trigger to an auxillary device (IE trunk release) so this is the wire that you want to use and it is found on the same harness as the BLUE instant trigger wire.
BUILD 2 IN PROGRESS
Old December 1st, 2008, 01:50 AM   #75
2007 Mustang GT
I think we don't understand each others
The trunk release ( red/white on alarm ) is correctly connected.
What I need to wire, is to detect the opening of the trunk. That's why I have to connect the car white/yellow (+) to the instant trigger on the alarm (-).
Old December 12th, 2008, 10:22 AM   #76
2007 Mustang GT
I did the connection as I described it below.
Now, when the trunk in open, it power the relay and the relay put the blue instant trigger to the ground.
But I lost the trunk light!
Old December 13th, 2008, 12:40 PM   #77
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
its going to do that because if you think about it the relay is changing the polarity of the signal so when is closed it is constant (trunk light off) but when the trunk is opened it activates the relay changing the negative trigger (trunk light comes on) to a postive to send the signal to the brain to activate the alarm and at the same time sending that same positive signal back to the ECM making it believe that the trunk is closed. On some vehicles instead of tapping into the door triggers you can take that same wire and tap into the dome supervision b/c there is no switch for the lights to come on or off with the doors so when the doors are opened the light comes on sending that output signal back to the brain setting off the alarm, except without a relay. In a sense this is what you did with yours except put a relay in between to change the output polarity thus killing your light when the trunk is opened. This is also considering that the wire that you were supposed to tap into is the same as the trunk light wire, which I belive it is.
Hope that I explained it good enough for you.
BUILD 2 IN PROGRESS
Old December 22nd, 2008, 06:37 PM   #78
2007 Mustang GT
ok. So what is the good wiring?
If the trunk is opened, the alarm blue wire ( instant trigger ) must be grounded.
I saw only one signal that show the trunk is open : white/yellow ( SJB blk 26 pin plug, pin 15 ) shows +12V.
Is there any hood pin on Mustang? I tried to use the purple/orange ( SJB blk 52 pin plus, pin 15 ) but it always shows +12!
Thank you
Old January 22nd, 2009, 03:40 AM   #79
2007 Mustang GT
No idea for my problem?
TY
Old January 22nd, 2009, 09:16 AM   #80
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
sorry bro, didnt see it. on mustangs there is actually no pin switch that exists to let the system know that the trunk is open. on some cars you will see a light on the dash showing that the trunk is open, unfortunately with ours there is not. the simplest way to do it is to use the pin switch that your system came with and use that or you can also purchast a mercury switch that you can tie on to something to enable that to work.
BUILD 2 IN PROGRESS
LinkBack to this Thread: http://www.moddedmustangs.com/forums/audio-video/87630-aftermarket-car-alarm.html
Aftermarket car alarm - Page 4 This thread Refback November 21st, 2008 02:15 AM
Threads Similar to: Aftermarket car alarm
Car Alarm Freaking Our help Blackbeauty v601 Audio/Video 12 September 3rd, 2008 01:05 PM
2-way FM car alarm medic_chris85 Audio/Video 8 August 24th, 2008 04:23 PM
Car Alarm Sunshine V6 Mustangs 6 January 8th, 2008 02:51 AM
Is this alarm system aftermarket on a 98 gt? Blue98GT Modular Mustangs 1 December 20th, 2007 06:12 PM
Car alarm locknest Audio/Video 5 February 18th, 2007 10:52 PM
