Matching Amp to Sub
Hello, all. I'm planning on buying this for Christmas;
Was told that it's a good, all around-sub for the price and for what I listen to: Country, rock, pop, tiny bit of rap. 300W in a 10" JL should surely be enough, right? Assuming all checks there, I need to know what amp to get. I don't want to overboard it, but please suggest what could safely match and handle this by a quality brand. (don't want to spend too much on it, either). Thanks!
![]() 2000 Ford Mustang 3.8L V6 Next Mod: Exhaust |
thats kind of a difficult sub to match with dual 2ohm voice coils. it would be easier with two subs. With the one you can either hook it up as a 4ohm load or 1ohm load. I cant find any 1ohm stable 300watt amplfiers. kicker has a 300rms amp but its 2ohm so that wont work. And if you want to get 300rms at 4ohms youll have to buy like a 1200rms 1ohm stable amp so that when its operating at 4ohm its about 300rms output.
A dual 4ohm would be much easier to work with cause its a lot easier to find a 300-400rms 2ohm amplifer then 1 or 4ohm. And this amp would do nicely and allows for upgradeability in the future if you get two dual 4 subs and then it can run 1ohm stable and output 600rms.
![]() 95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit, GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp 96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap |
That doesn't seem too bad at all. Can you match up any good boxes for that? My int is tan, and I think the trunk is too, hafta look at it later.
Scratch that. charcoal grey carpetting
i dont see any custom boxes made specifically for the mustang but their are a lot of different types of single 10" sub boxes. Heres just one, but their are many
i built my own for a 10 in my stang with a wedge on front and back.
if u are alright with woodworking, its not TOO difficult and can save you quite a bit of money. ![]()
Rockford Fosgate makes plenty of 4 ohm bridged app amps lemme fin one real quick http://www.rockfordfosgate.com/produ...n_US&p_status= Yeah it's 300 bones but has a great warranty (like you'll ever need it! RF dont play!) and it'll beat the shit outta your JL and your car if you want it to. I have 4 of the same series amps (RF 600.2) running the 4 10's in my Monte Carlo (all older RF power He2 subs) and can produce around 120db in sea;ed boxes (not pro #'s but is what my meter reads @ 55hz)
Yeah, its ugly, but hot damn its fast! Got 2 camaro SS's and 1 LT1 vette under mah belt in it! |
Threads Similar to: Matching Amp to Sub
| Color Matching By Mail | OcOnnor220 | The Clubhouse | 6 | September 24th, 2007 08:39 PM |
| Paint Matching | OcOnnor220 | 99-04 | 3 | August 9th, 2007 02:19 PM |
| port matching pi manifold | slow98gt | 96-98 | 3 | May 11th, 2007 08:27 PM |
| Exhaust port matching | Zak | 5.0 Mustangs | 0 | May 4th, 2007 01:48 AM |
| Scoops and bumper color matching ? | Redline | V6 Mustangs | 15 | January 29th, 2007 06:25 PM |
