Need help on suspension
Hello,
Well its the first time im taking a heavy big car to autocross pretty soon. I had my miata perfectly tuned for autocross and it was so much fun. I remember our miatas use to dominate the course all the time, but now i have something different. So its going to hard, but so much getting to know a new car. I was wondering what kind of sway bars does everyone recommend for the fox bodies? Looking for something pretty stiff for the rear. The other thing i heard about the diff on my 89 shifts side to side on cornering, and can snap you into oversteer. I was reading up that a panhard bar helps out, but is their a do it yourself panhard bar tutorial out their? Also is their any tips you guys can give to a new owner of 89 gt completely stock. Thanks |
3rd Place '11 ROTY
'02 GR-40/SLA Saleen
19.34@42.259
You will need to work on the Fox to get to your standard
![]() I would begin with some serious frame support via SFC's and go from there. To answer your question, YES, you can certainly snap-oversteer in your Fox and can be corrected via PHB or WL and a torque-arm. As for doing one yourself, do you mean "manufacturing" one yourself or just purchase and install? Head over to The Official Suspension Guide by our own MM97GT and read about 13 pages of suspension goodness. Welcome to MM's and see you at AX ![]() Jazzer
Thanks Jazzer for the link really is helping with other questions i had. Yes i thought i would be able to manufacture my own panhard bar, only thing i dont know how if theirs a link or diy site to follow up on, that would be great. Thanks again
Priest of the Car Gods
Should've stuck with your Miata and just done the motorswap to a 5.0, hahaha.
You're going from a very well designed fully independent suspension (I beleive they're SLA all four corners, yes?) to one of the WORST suspensions on the road. Inboard spring McPherson strut front end and a HORRIBLE 4-link design in the rear couple with a very flexy chassis means that you're gonna end up replacing almost everything to get it settled down and predictable. I wouldn't even look at swaybars yet. The absolute first thing you need to do is chassis bracing. Full length, weld-in Subframe connectors are a necessity for any sort of performance application. After that, I'd go for caster/camber plates. The stock front geometry is greatly improved with a good dose of caster, and there's no way to get it without CC plates. I've seen people do their own panhard bars, but honestly, the price of an aftermarket one makes it not very worth it in my mind to roll your own. MM makes a good unit that works around stock rear-exit exhaust that's not much more than $300.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
Any links where to purchase the panhard bar?
Maximum Motorsports :: The Leader In Mustang Performance Suspension
Griggs Racing Products I'm sure there are others, but those are the two I suggest.
Threads Similar to: Need help on suspension
| Steeda Suspension- Suspension Questions | MustangJon255 | 2005 - 2010 | 22 | June 2nd, 2010 06:43 PM |
| Need Suspension | temple30 | 5.0 Mustangs | 14 | September 3rd, 2008 07:29 PM |
| suspension ?s | mustangsoldier | 5.0 Mustangs | 8 | August 31st, 2008 06:39 PM |
| suspension | mtndew | 2.3 Mustangs | 7 | May 21st, 2007 08:14 AM |
| suspension | kratos2250 | 5.0 Mustangs | 4 | March 3rd, 2007 10:47 PM |
