Rear end shot, looking to start right for getting into AutoX
Go Back   Forums at Modded Mustangs > Mustang Forums > Racer's Corner > Autocross
Old June 12th, 2011, 10:26 PM   #1
jqualls04GT will become famous soon enough
I need to fix my rear end, and I want to get into autox as soon as I get my car setup the way I want it, not the PO.
The ring gear bolts installed w/ 4.10s by the PO rattled out and ate up the internals pretty good. So, I used some grade 5 bolts to get me back home. They are no longer bolts, but rather very short studs! So I figure since my carrier has a good ding/rip in it (about 1" starting at one of the openings) I am going to go ahead and upgrade to 31-spline axles. I can get the kit from LRS that has everything I need in it for ~$1090:1999-04 Mustang 8.8" 31 Spline Severe Duty Rear Axle Kit, 31 Spline, 4.10 Gears. But I'm not too sure about the locker for autox. Would I be better off with a 31-spline Trac-lok? Or some other diff? Besides Moser's $1k+ "wave action" or whatever it is. Thanks in advance.
When I start going to events, it won't be all the time, though, just hopefully once a month/ month and a half. I plan on going turbo eventually, so I probably won't be doing it very long, since boost isn't the best for autox (from a couple of thread s I've been reading through, but I have plans on alot more reading since I'm living on my ship for a while).
31-Spline upgrade in progress!!
My stang burnout vid!
Old June 14th, 2011, 02:48 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
First thing I recommend is checking the rules for whatever class you're gonna run in where ever it is that you're gonna run. Some classes only allow you to keep the stock LSD, some updating and backdating within the same model (i.e. you can use any LSD so long as it came out of a Mustang), and some are totally open as to what you can do.
With that out of the way, I've heard really good things about the Torsen T2-R, though I have no personal experience with them. Last I checked, those were running about $600.
O o
/¯/______________________
\_\
Old June 22nd, 2011, 03:39 AM   #3
Thanks, RD, I decided I might as well upgrade to 31 spline axles. Especially since LRS has the diff on sale for less than $200! I'm getting a set of Richmond 4.10s for ~$140 and some ARP ring gear bolts (~$24). Now I'm looking at axles. I am probably going to go with Summit brand since they usually have top manufacturers make their parts; any thoughts on why I shouldn't do this? Only thing not ready for shipping is the axles and an install kit. I will probably get a cover later on after tow and registration funds.
Old June 22nd, 2011, 04:29 AM   #4
Oh yeah, the car has less than 60k miles, since I got it w/ 62k on the clock and untuned 4.10s I put 5k on it in 3mos? I don't think so. So I'm not sure whether or not I should get an install kit with or without bearings. ? thanks.
A link to which kit to buy would be helpful as well! I am about to search the forums, but idk how much info I can turn up with that.
Old June 22nd, 2011, 07:29 AM   #5
01KnightRiderGT's Avatar
2001 Mustang GT
01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about
Send a message via MSN to 01KnightRiderGT
I would swap out the 4.10's for AX, you will find your self redlining 2nd all the time. For AX, your generally stay in 2nd gear. 3.73's would be a fine choice.
Black Stang Member #13
315's Crew Founder
My Track Videos
Old June 22nd, 2011, 01:24 PM   #6
Just an FYI, Summit brand stuff usually is NOT top-brand stuff. It's usually whatever the cheapest of the name-brand stuff is. For instance, the mustang suspension parts they use are of a certain manufacturer of particularly ill repute.
I'd pay the extra for whatever LMR is selling. Summit's reputation is on having whatever part you're looking for and having it cheap, LMR's is on selling high-quality parts. Do you really want to have any question when it comes to the durability of your half-shafts?
I would definitely do the install kit and put fresh bearings in. You're already in there and messing with that stuff, might as well reset the clock on those parts as a while-you're-in-there.
And +1 to not just jumping to 4.10s. For typical AX courses, you're shooting to have your car redline at 60 mph in 2nd gear. That should make it so you never have to shift into third. If your group has faster courses (e.g. the group I run with typically has at least one part of the course that the faster cars can hit 70-75), then you may want the lower gears, as you'll be in 3rd anyway. I'd do some runs, see how fast you're actually going, and do the math as to what's gonna be best for you.
The flipside of gears is that you're likely traction-limited as it is. I know with a torque arm and Star Specs I can *still* spin the tires with 2.73s, and I only dyno at 194whp!
O o
\_\
Threads Similar to: Rear end shot, looking to start right for getting into AutoX
Cart CT AutoX trialmaster Autocross 0 May 18th, 2011 07:33 PM
Autox in NC? Jimmyc206 Autocross 2 November 14th, 2010 10:27 PM
My Autox project Mustang Boy Autocross 23 July 19th, 2010 10:18 PM
rear end? start prob? KV007 94-95 4 July 27th, 2009 01:20 PM
i think my rear is shot... 03gtfirered 99-04 22 December 8th, 2008 04:46 PM
