LinkBack (1) | Thread Tools |
#1
What wheels are safe
I recently bought a Mach 1 that a taking to an open track day at the local road course. The car has 18 inch Bullitts on it. I am sure they will be okay for a day, but will they hold up to repeated road course races with-out failing. I am a little leary of some imported wheels. Any suggestions on forged wheels that won't bankrupt me.
Pick up a set of factory 17 inch rims
Abyssinian of AX
'02 Saleen
19.34@42.259
Mustang... your existing wheels will be fine, unless they are damaged in some way.
Open track can accelerate tire wear and be hard on brakes, but will likely not be bad on your first trip. Far and away, the biggest issue would be the potential for brake fade issues, due to heat. If you really get into this endeavor, you are probably gonna need to address brakes as the very first big uprade for future HPDE days. My recommendation.....? Take your car EXACTLY how it is, with the exception of some failing parts and have fun ![]() What performance mods do you have currently? What tires are you running? Have you open-tracked prior? Jazzer
#4 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
The information above is what I will stick to, mister
![]() Your car will be just fine on your first day out. You should NOT be pushing it hard at all, IMO and just work on your lines and corner entry/exit posture. How many laps/hours will you be doing and what track is it? Are you going with a club or private lessons or what? Jazzer
It's a "Flat out" day. 3 or 4 hours. An instructor rides in the car with . It's at Beaver Run.
Abyssinian of AX
'02 Saleen
19.34@42.259
No prob
![]() Once you get a few days like this under your belt, we can talk about some good mods to address those issues you feel need it. I know several things you should notice, but I'm not telling you right now You need to see/fee/experience them for yourself, so you have first-hand knowledge You have some nice tires, so just pay attention to how she responds under hard cornering/braking conditions.Just drive her as she is and let the instructor give you some pointers and have a good time ![]() Jazzer
What club is it? Im running stock gt but i have moved up tO toyo ra1s and i have plans for coilovers and some hoosiers when im ready for them. I open track day at mid ohio. Do mach 1s have 13 inch rotors? Make sure after you get done running change youre oil filter after you run and cut the old one apart and check for metal shavings. Running open track is very hard on a motor and you have alot more rotating parts with it being a mach1
![]() Check out our race team! http://www.facebook.com/media/set/?s...3927011?v=wall American Iron Mustang- ^1.6 lateral gs 03 Steeda 1.2 lateral Gs-ra1 08 Gt |
let me tell you, when i went from the stock brakes to the brembo kit, it is such an amazing difference
![]() 1998 Escort ZX2 2000 Mustang GT Saleen body kit, BBK CAI, SLP LM1, MM FLSFC, Tociko Spec Ds, 18" FR500s, MAC catted X, 3.73s, PHB, TA, LCAs |
Abyssinian of AX
'02 Saleen
19.34@42.259
^ Brembos are nice, as I run them up front myself, but I can tell you that with proper upgrades of pads, fluid and SS lines, the OEM brakes will be just about as good as the Brembo's. The difference being a bit better cooling on the Brembo's, a slightly better mechanical advantage due to larger rotor and a bit less flex on the calipers.
The OEM calipers and rotors are just fine and especially for something like AX ![]() Jazzer
ahaha the stock stuff is good unless the right front caliper stops working
Abyssinian of AX
'02 Saleen
19.34@42.259
Silly boy.....
#13 | |
= equals pad. normal ________ ,,,,,,,,,,,=.............= ,,,,,,,,,,,=.............= ,,,,,,,,,,,=.............= after overheating ________ ,,,,,,,,,,,,,,,,,,,,,,,,,=............= ,,,,,,,,,,,,,,,,,,,,,,,,=..............= ,,,,,,,,,,,,,,,,,,,,,,,=.................= (wouldnt keep my spaces) the calipers overheated so much and having force pressing them apart the calipers were shaped like somebody had put a huge wedge in between the sides and pressed it apart. cobra calipers did wonders for me and i also added brake ducting. and some decent pads to the car and it feels like you going to go through the windsheild when you stomp the brake. on dads racecar we actually run stoptech calipers but thats another level of racing from what are cars do.
![]() Check out our race team! http://www.facebook.com/media/set/?s...3927011?v=wall American Iron Mustang- ^1.6 lateral gs 03 Steeda 1.2 lateral Gs-ra1 08 Gt Last edited by 94racing; August 29th, 2011 at 05:41 PM. Reason: spaces wont work? |
New Boss
THE most common 'brand' of wheels found at the track is 'Enkie'. They make forged aluminum wheels that are cost-effective for the 'least-wealthiest' of us track whores. They're also some of the lightest. You could find a set for the 'Stang (18x9) that weigh less then 20lbs ea. All in all they make a TON of different styles, but the most popular wheel with track guys seems to be the RPF-1. It's a copy of the wheel they use in Formula 1, and is about the lightest(an 18x9 should be around 18lbs), yet just as strong as any other wheel they make-which is much stronger than you'll ever need.
FWIW wheel weight is one of, if not THE most crucial place to lose it, as it's 'un-sprung' weight. It affects pretty-much everything from acceleration,to turn-in, to spring tension and shock damping. Search some track junkie sites..
'12 Boss 302-Competition Orange |
We have a set on enkie pf01s and 3 sets of forgeline(lightest wheel you can get) and theyre around 1k a peice though. Also have two sets of steeda wheels but i may have 1 set sold. I dOnt have anthing bad to say about any of the wheels. My favorite are the enkies for Price to what you get. Next would be the steeda then the overly priced fOrgelines
1998 Mustang GT
Be carefull with the lightweight rims, you hit a set of bumpy gator strips you gunna be buyin more rims is all i gotta say. and you go to one hpde event, you hooked!
98 Mustang GT Mods:Flowmaster 40's Pypes O\R X-pipe Ram Clutch BBk CAI Pro 5.0 Shifter. mm c\c plates, 3.73s, cobra brakes with stainless lines, hawk blue pads and bfg r1 race tires. (for track) Ford racing race springs. Black DD FR500s
Never had a problem with that. What wheels were you running when that happened? We run the forge lines which are extremely lightweight then the pf01s and have had no problems on the striping. Jeff actually offtracked his forgelines and they are still fine
1998 Mustang GT
actually had a buddy i run n.a.s.a with ran over some rumple strips with some rpf1s and bent one. at CMP. i dont have lightweight rims. so actual input from me is none haha
i actually dont like the rpf1 design it just didnt look strong. i also run nasa. what level of hpde are you in? i just progressed to level 2 and they said by the end of next weekend i should be in level 3
1998 Mustang GT
Ive only run 1 weekend with nasa (2 overall) and hpde 1 and possibly 2 after another weekend. i ran with the mustang club, that was my second weekend and compared to nasa it was a joke, they put me in the second group and i was still passing cars lol.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/autocross/228320-what-wheels-safe.html
| Thread What wheels are safe | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 22nd, 2012 09:47 AM | |
Threads Similar to: What wheels are safe
| Would these be a safe buy? | whyxitx | V6 Mustangs | 7 | November 10th, 2010 08:14 PM |
| how safe? | DeMello | 99-04 | 67 | June 9th, 2008 04:18 PM |
| Is it safe? | RC02GT | 99-04 | 20 | April 19th, 2008 11:13 PM |
| Safe To Say? (Heavy Wheels) | JAY'SRED02 | 2005 - 2010 | 7 | November 28th, 2007 03:45 AM |
| Is It Safe To Rev To 6k? | 97GOLDGT | 96-98 | 26 | November 11th, 2007 04:24 PM |
