Building an auto-x/roadcourse car - Page 2
Go Back   Forums at Modded Mustangs > Mustang Forums > Racer's Corner > Autocross
Old October 19th, 2011, 01:46 PM   #21
94racing's Avatar
2006 mustang gt500racecar
94racing will become famous soon enough94racing will become famous soon enough
Originally Posted by JakeM View Post
390RWHP? What is done to it? That is a lot of power from a N/A 3 valve.
what isnt done to it? block is original bore but aftermarket crank/rods/pistons/oil pump/cams/heads/race tune/race fuel and anything else you can think of motorwise along with a ford racing tranny,flywheel,driveshaft,griggs rear end and some forge lines. the weight of youre wheels make a huge difference with youre horsepower.
with the boss 302r the motor is supposed to be pushing 440 crank but i was standing by the dyno and watched a new boss 302r prebuilt racecar with a different tune push 407 rwhp (rehagen) before they detuned it. you lose at least 15% power through driveline normally more making that around a 468.05 roughly out of a stock boss 302 motor with a race tune from rehagen! we are running a 360 tune on the racetrack while they run a 360 also but they have such different curves they hold power sooner and longer as compared to 3v so thats really the only reason were switching. that and we got a boss 302r at dealer warehouse cost.
the motor had the new ford racing oil pump go out and we immediately shut it down and pulled the motor apart. still had oil in all of the places it needed to be and no scaring or anything on anything. so the new pump is on its way and atlanta is going to be our test on the motor before it goes up for sale.
Check out our race team!
http://www.facebook.com/media/set/?s...3927011?v=wall
American Iron Mustang- ^1.6 lateral gs
03 Steeda 1.2 lateral Gs-ra1
08 Gt
Old October 19th, 2011, 04:31 PM   #22
BWAL Is My Hero
JakeM's Avatar
2003 F150 S-Crew 5.4 FX4
JakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant futureJakeM has a brilliant future
There is a huge difference between the 3 valve and the 302R motor..... I'd think that 3 valve would be more like 360-375 RWHP unless it is REAL high compression. I totally believe the 302R motor making monster power, but the 3 valves have trouble making a lot of power, especially with the stock intake, passed 350RWHP when naturally aspirated.
*My YouTube channel*
Member# 1 of the Zip Nutswinger Bandwagon of Love.
Originally Posted by dr.gonzo? View Post
That drunk guy ran like I do after I fart in the store
Old October 19th, 2011, 11:59 PM   #23
94racing's Avatar
Has a ford racing intake on it ill slap a dyno sheet up tomoro if i get free time. Have school 9 hours strait
Heres a video though 360 rwhp with the throttle body limited through the higher rpms. 380 was the max at pauls automotive dyno but we put cams built for this specific engine by compcams in it and gained 10 more hp but im pretty sure dad has the dyno sheet in his breif case. Ill hopefully get it posted tommoro.
08 Gt
Old October 21st, 2011, 11:10 PM   #24
94racing's Avatar
i need to look in the racecar trailor tommoro and see if i can find it.
08 Gt
Old October 22nd, 2011, 12:45 AM   #25
BWAL Is My Hero
JakeM's Avatar
Big difference between 390 and 360RWHP. How is the TB a restriction on a N/A Car? Not trying to be a dick, that just doesn't sound right to me. Or do you mean it had a restictor plate on it? IIRC, Rich was able to make that much power, but it took a JPC intake, full bolt-on's and custom cam's and it was BEARLY 390RWHP at the very top of the curve. Which wouldn't be ideal for a road racing build. Gotta have power under the cure to come out of the corner. Which I'm sure you are aware.
Old October 22nd, 2011, 05:23 PM   #26
At the Apex pulling 1.2g
Whiskey11's Avatar
2009 Mustang GT
Whiskey11 is just really niceWhiskey11 is just really niceWhiskey11 is just really niceWhiskey11 is just really niceWhiskey11 is just really nice
Send a message via Yahoo to Whiskey11
Rich? From RAD stangs? He had the stock bottom end, no stroking or compression change or anything like that.
I believe the restriction is per class rules but I'm not quite sure to be honest.
20 May 2012 Auto-X event after action report:
http://www.moddedmustangs.com/forums...nals-site.html
Old October 22nd, 2011, 08:15 PM   #27
94racing's Avatar
the youtube vid was what setup we are running when we run the car on the track. its a hp to weight ratio rule. i guess it was 380 but thats with the old cams when we added the custom made cams by comp cams at our 360 hp tune it bumped the power up by 12 hp. so with that said the estimate was 10 hp gain and just so you know. s197 thottle boddys you can restrict how far it opens at certain rpm which is how we made our 350 and 360 hp tunes. with the added custom cams those tunes are now 362 and 371 hp tunes with added cams.
so making that assumed means 390. figuring i mean. but everything in this motor is aftermarket. which i found the blocks even aftermarket earlyer. and it is a high comp engine.
btw poe motorsports had a 3v pushing 420rwhp and hes got 2 years on the motor completely built.
08 Gt
Old October 24th, 2011, 07:24 PM   #28
EscortSportage's Avatar
1989 Mustang GT 5.0
Id say, stay away from adjustable struts and shocks. U want to get the struts and shocks that are matched for ur spring rate
And like dexter said stock hp is enoug...(im finding out after i went turbo..i think im going back to na )
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old October 24th, 2011, 09:43 PM   #29
94racing's Avatar
how much power are you pushing?
and are you saying to go with sla?? griggs!!!!
jk
suspension wise you will figure out what works and doesnt the longer you stick around.(aimed at atrainsgt)
atrainsgt my motor was sorta a offer if you want a price you can pm me.
08 Gt
Old October 24th, 2011, 11:08 PM   #30
1989 Mustang GT 5.0
I didnt say anything about sla...
I broke 520rwhp with too much boost(ran out of fuel at 4k had to shut her down)
Now running 4lbs of boost and idk what she puts down
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old October 25th, 2011, 12:13 AM   #31
Whiskey11's Avatar
2009 Mustang GT
The premise behind adjustable shocks and struts is to match two shocks that previously where not matched from the same manufacturer due to tolerances in making the shocks. Of course to do so requires a shock dyno (big $$$$) or pay to have all of the adjustment values tested (also $$$$$). Ideally the rebound and compression curves SHOULD be done through the valving.
Unfortunately, you will rarely find anyone who uses them as such. I agree though, sometimes having tons of adjustability goes a long way to creating headaches!
Stock HP is def enough. I'm not surprised that Vorshlag's 2011 5.0 in STX is having issues. Some of the first mods they did were power mods on a car that is already undertired from the factory and undertired on "street" tires. They still haven't addressed the rear end issues with the allowable modifications for live axle cars (Watts link and Torque Arm) and they complain that the car just can't do it. I really hope they don't give up without maxing the prep level. With the new Street Touring rules in the Fast Track this month, Mustangs under 5.0L of displacement are stuck in STX with no hopes for wider tires or rims than the current allowances. 265's on 9" wide rims and 400+ HP is a recipe for disaster. I wonder what an 05-10 S197 would do in STX trim.
Old October 25th, 2011, 06:59 AM   #32
1989 Mustang GT 5.0
Idk anything about track classes. Im prolly fugged. Seeing the amount of mods i have..
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old October 25th, 2011, 08:16 AM   #33
June 2010 ROTM
Serlin's Avatar
2000
Serlin is a jewel in the roughSerlin is a jewel in the roughSerlin is a jewel in the roughSerlin is a jewel in the rough
Arrow
OR:
You could just buy my car for 12K and go racing
Full Maximum Motorsports catalog, and supporting mods.
See my garage for pics
PM me if interested
HPDE Instructor
PCA, HOD, Track Guys, ERME
www.RaceCarTowHooks.com
My Track Videos http://www.youtube.com/user/Msirlin
My Garage page: http://www.moddedmustangs.com/forums...-member-17090/
Old October 25th, 2011, 08:27 PM   #34
1989 Mustang GT 5.0
I like my fox
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old October 26th, 2011, 12:55 AM   #35
94racing's Avatar
Originally Posted by Serlin View Post
OR:
PM me if interested
Ooo i want. Just dont have that type of money laying around being in college. Would be a good buy although i have no clue what class youre car could run other than tt with nasa
08 Gt
Old November 23rd, 2011, 02:53 AM   #36
Look Ma! My First Post!
ponyracer is on a distinguished road
My suggestion is to start with the SCCA 2012 rule book and figure out what class you can afford. I race ESP and through a friend found a loop hole that allows the T-1 class cars to race ESP. This sounds like the same place your at. I too have a 5.8 building for my 94 GT but the 94 Cobra 5.0 that I have is plenty enough to run around the track until I get a better suspension setup and tires. Everyone has good advice but it all comes down to the rules so get the book and read and study it and follow it like it is the bible. I would think that the 5.8 would do better road racing as autocross is short runs and rare long straights. For what it is worth, this is what I have been told, verified through the rule books and experienced.
P.S. my biggest problem is that on my "no money budget" I can only do so much and desperately need to find sponsors to augment my expenses.
Threads Similar to: Building an auto-x/roadcourse car
2004 V6 Auto VS. 2010 Charger V6 Auto 04Sixxer Racer's Corner 13 February 13th, 2012 11:16 PM
First time on a roadcourse earlier today! Got questions! Jazzer come in! 01MGGT Autocross 34 March 28th, 2011 04:48 PM
Anyone swapped their 4speed auto to a 5speed auto ckkone 99-04 1 September 17th, 2010 12:54 AM
'02 4spd auto to 5spd auto swap...possible? digicjm V6 Mustangs 3 April 29th, 2009 11:14 AM
Auto Zone/ Adv Auto Parts REMAN Engines rusty2407 5.0 Mustangs 19 May 6th, 2008 08:45 AM
