Steeda K member
Has anyone ran this?
Steeda Lightweight K-Member for 1996 thru 2004 Ford Mustang 555-5078 Looks expensive but it will still use factory control arms and springs. I kinda like that Idea. Anyone got one or know of one? |
no idea but i like the products they carry. go for it
![]() Check out our race team! http://www.facebook.com/media/set/?s...3927011?v=wall American Iron Mustang- ^1.6 lateral gs 03 Steeda 1.2 lateral Gs-ra1 08 Gt |
1989 Mustang GT 5.0
you want to use factory springs? and a arms?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
1989 Mustang GT 5.0
900 dollars to use factory crap....uhhh u need to call MM
![]() Join Date: Jun 2011
The weak link in the factory set up is the K-member. The factory control arms actually are very good. A tubular A-Arm with a spring perch that is as strong as the factory is not a huge advantage over stock pieces. Most tubular control arms are for coil overs. We built this to be used with the factory arms and factory style springs. Though it will accept stock replacement tubular control arms. This also allows this K-member to be used in race classes that require stock type front suspension.
Our K-member also features 2 lower control arm mounting positions for fine tuning of roll center geometry. One position for cars at stock ride height or less than 1" lower than stock. The second position is recommended for cars 1" to 1 1/2" lower than stock. The steering rack can also be positioned in the stock location but, we made it adjustable for changes to the Ackerman geometry. Ackerman is the term used to describe steering geometry that causes the inside front wheel to turn "tighter" than the outside front wheel. Not trying to sound like a infomercial, but that is the gist of our K-member. It is much different than anything else out there. LEt me know if I can be of anymore help. Thanks
1989 Mustang GT 5.0
under stood, im running coilovers, so i see if ppl want to stay stock front susp.
13.2@105.66
![]() iTrader: 3 reviews
Side question, is there a way to get the q400 hood for an 04 GT with the louvers open? Is there anything to close them back up once you are done at the track?
![]() JLT CAI, Bullit intake swap, SCT tuner (custom 93 octane tune), MAC LTs, o/r prochamber and catbacks Steeda pullies, Bilstein HDs, 300 lb coilovers (front), MM Road and track TA springs (rear), MM panhard bar and TA, Torsen T2R 2012 Boss 302 |
search around on the web, you can find them way cheaper than $900...
#10 | |
Threads Similar to: Steeda K member
| Steeda K-Member? | Bullitt5339 | 99-04 | 5 | May 16th, 2010 09:39 PM |
| Anyone installed Steeda Bumpsteer with Steeda Springs | YeloPony | 99-04 | 3 | January 6th, 2010 06:20 PM |
| Steeda Qa1 Tubular K Member | mustangmanic | 99-04 | 1 | June 9th, 2009 11:01 PM |
