any one with a fox using 03 cobra steering rack?
Go Back   Forums at Modded Mustangs > Mustang Forums > Racer's Corner > Autocross
Old December 7th, 2011, 10:40 AM   #1
EscortSportage's Avatar
1989 Mustang GT 5.0
im debating the cost to benefit for this setup
MM hybrid steering shaft
Brand new 03 Cobra steering rack
some different tie rods etc etc
how is the steering response and feel compared to a stock fox steering setup with an MM steering shaft?
is this worth it? or can this wait?
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old December 7th, 2011, 10:46 AM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Subscribed... my rack needs to be replaced anyway, curious what all would be involved in this swap.
O o
/¯/______________________
\_\
Old December 7th, 2011, 10:53 AM   #3
1989 Mustang GT 5.0
standby,
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old December 7th, 2011, 10:55 AM   #4
1989 Mustang GT 5.0
all From MM website
New! MM now has a Hybrid Steering Shaft Assembly that allows the installation of an SN95 (1994-2004) power steering rack into a Fox (1979-93) chassis Mustang. The SN95 steering racks are a good upgrade for a Fox Mustang because they provide improved steering feel, with slightly higher effort and more linearity than the Fox steering rack.
With the new MM Hybrid Steering Shaft Assembly the SN95 steering racks can now be easily installed in a Fox chassis Mustang. The MM hybrid shaft assembly has the correct lower U-joint to connect to the unique triangular-shaped input shaft of the SN95 steering racks. This MM hybrid assembly also features a splined joint to allow correcting the orientation of the steering wheel. This feature is required to properly center the steering wheel with the SN95 steering rack. Without this unique MM shaft the steering wheel would be rotated nearly 90 degrees from center, which is far too much to be corrected by adjustment of the tie-rods. The stock steering wheel and airbag (if so equipped) are not disturbed.
The MM Hybrid Steering Shaft Assembly is constructed with all of the great features listed above for our other high performance steering shaft assemblies. No setscrews!
Fox chassis tie-rods are required because the SN95 tie-rods are too long for the Fox chassis front control arms. The correct length tie-rods can be easily swapped into place because the inner threaded connection, where the tie-rod attaches to the steering rack, is the same. Note that the threads on the tie-rods, for attaching the outer tie-rod ends, are different between the SN95 tie-rods and the Fox tie-rods. This will dictate which outer tie-rod ends must be used.
For those using the longer SN95 front control arms on their Fox Mustang, and who will be using an adjustable outer tie-rod end bumpsteer kit, there are two options to choose among for tie-rods and outer tie-rod ends. The longer SN95 tie-rods can be used, which will require an SN95 adjustable outer tie-rod end kit. Or the shorter Fox tie-rods can be used, along with our MMTR-6 tie-rod end kit. This kit has a longer aluminum adapter sleeve that effectively lengthens the Fox tie-rod to match the longer SN95 front control arms.
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old December 7th, 2011, 10:58 AM   #5
So, basically you can swap to an SN95 rack with the rack, your existing tie-rods, and a hybrid steering shaft?
O o
\_\
Old December 7th, 2011, 12:00 PM   #6
1989 Mustang GT 5.0
thats what im thinking, i talked to MM they said the 03 cobra or 04 cobra....think its 03 cobra has the BEST steering rack (so why waste our time with 94 to 2002 stuff)
only thing (picture me walking into a ford dealership asking them for a new 03 C rack)
im curious to see how much money it is, cuz shit ill do the swap when i do my MM k member
MM k member,a arms, rack bushings, swaybar, swaybar reinforcement kit with a MM hybrid shaft and 03 cobra rack....would be an AMAZING improvment
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old December 7th, 2011, 12:35 PM   #7
Rock Auto has reman racks for $150 + $100 core... but I can't find anything that says they're '03/'04 Cobra specific (the application guide says "03/04 Mustang"... so maybe it is because it doesn't say 94-04, or maybe it's not because it doesn't say Cobra).
I'm honestly not sure what the difference in the racks was between the NE GT and the Termies, so I'm not sure if a reman unit would retain those differences.
O o
\_\
Old December 7th, 2011, 12:38 PM   #8
1989 Mustang GT 5.0
thats what im saying is we need to make SURE its a 03 cobra why waste ur time with anything else, if we are going to do the work,.....
sooo they will take my POS 89 rack as a core?
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old December 7th, 2011, 12:40 PM   #9
Will they know the difference if you don't tell them?
O o
\_\
Old December 7th, 2011, 01:19 PM   #10
1989 Mustang GT 5.0
hmmm....and then u go to a ford dealer and buy my old stock (2003 cobra) rack LMAO
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old December 7th, 2011, 09:57 PM   #11
1989 Mustang GT 5.0
240 dollars! (MM hybrid shaft)
damnit! well i guess ill sell my exsisting MM shaft
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Threads Similar to: any one with a fox using 03 cobra steering rack?
can i use fox steering rack on my 95? STREET6 5.0 Mustangs 2 March 1st, 2012 07:58 PM
95 GT steering rack 95RED5.0 94-95 0 August 7th, 2011 02:07 PM
steering rack jesusm3 5.0 Mustangs 10 May 25th, 2010 07:36 PM
Steering Rack Novanutcase 99-04 0 July 28th, 2009 03:00 AM
Steering rack ???? UPRNewEdge 99-04 0 June 21st, 2009 01:36 PM
