First time
Go Back   Forums at Modded Mustangs > Mustang Forums > Racer's Corner > Autocross
LinkBack (1) Thread Tools
Old July 27th, 2008, 11:57 PM   1 links from elsewhere to this Post. Click to view. #1
sjr56's Avatar
2001 MUSTANG GT VERT
sjr56 is on a distinguished road
First time
I just spent the weekend at a 2-day event. What a blast!!!!!!!!!!!!! Can't wait till the next one. Did realize that I don't have the setup to compete in ESP.
Even so, I got considerably faster each run and was only off course once.
Gonna set the ft. end alignment for the twisties instead of for drags and try some "street legal slicks" and have at it again.
Any one have a good alignment setting?????
How about good tires for ESP class????
Old July 27th, 2008, 11:59 PM   #2
347stroker's Avatar
347stroker is on a distinguished road
Asume your talking about a road race correct.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's
Mineral Gray Club Member #1
Old July 28th, 2008, 12:00 AM   #3
347stroker's Avatar
nevermind I didnt realize which one I clicked on lol, I think that would be a blast to try but there isnt anywhere close to do it at.
Old July 28th, 2008, 12:20 AM   #4
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Glad to hear you had fun! I wouldn't worry about being competitive in your class just yet, the fact that you're getting faster each run is very good.
For your alignment, it's really going to vary based on your suspension, but the general rule is that you want a couple degrees of negative camber and as much positive caster as you can get. Tire temps are a good way to determine how well your supension setting is working - assuming you have a probe style pyrometer. If you do, after each run, measure the temperature at the inner, center, and outer part of each tire. Write it down. The temps should be even across the tread. Adjust each setting individually until the temps are as close as possible, then work on the next adjustment. Tire pressure is also very important!
If you don't have a pyrometer, you can also use the chalk trick to determine how much air pressure you need: take the chalk and draw lines all the way across your tread and up the sidewall in at least three places on the tire. Check how the chalk's worn off when you're done with your run. If it's being rubbed off the sidewall, you need more air.
Good tires is a debate. I know last year the Falken Azensis RT-615s were top dog, but that means a whole lot of nuthin' this year. The Kumho Ecsta MX is supposed to be a good autocross tire, as well. Tire choice will also be dependent on whether or not you want to run race rubber or street tires. I'm looking at Toyos to replace my current Kumho allseason rubber - the Cobra doesn't have to pull DD duty anymore, so I can finally put some high-perf summer tires on there.
Again, glad to hear you enjoyed yourself!
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old July 28th, 2008, 10:34 AM   #5
sjr56's Avatar
Thanks Dex, I appreciate the info you gave before. The pressures you gave me worked ok and another competitor hooked me up as far a dropping pressure till I started rolling the tire. Funny thing was my fastest run was also the most fun (drifting thru both ends of the course). Pretty happy though ended up with a 51.2 to the winning 47.9 and its a prepped ESP car w/race rubber. Ready to go again already...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/autocross/82063-first-time.html
First time This thread Refback July 28th, 2008 12:38 AM
Threads Similar to: First time
About time 707Stang The Clubhouse 2 June 10th, 2008 03:21 PM
1/4 time worlz08 5.0 Mustangs 6 May 27th, 2008 12:56 AM
New member first time poster long time fan kpmorris New Members Introductions 14 August 20th, 2007 12:53 AM
No time QuEeNiEsTaNg V6 Mustangs 15 November 24th, 2006 04:08 PM
New Best Time orangeRcode Drag 9 November 21st, 2006 10:43 AM
