oil control
Go Back   Forums at Modded Mustangs > Mustang Forums > Racer's Corner > Autocross
Old September 14th, 2008, 12:46 AM   #1
greddyt56 is on a distinguished road
oil control
Is the stock oil pan provide good oil control for autocrossing? I know if I am going to go road racing I should probably get a baffled oil pan, but for now I just want to autocross. Do I need to overfill? I dont want to blow my engine because of oil starvation. I did that once already when I used to autocross my old 1997 v6 f150.
Old September 21st, 2008, 05:32 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I know I've never had an issue in the Cobra; I keep my oil "in between the lines", never seem to have oil pressure issues.
I don't think most corners in autocross are long enough to starve out the oil pickup tube.
If you were really worried about it, I'd get one of the oil accumulator systems that holds 2 quarts, and injects the oil when it senses the pressure drop (then recollects it when pressure is recovered). One of these would give you the added advantage of not having your top end be dry on engine start.
O o
/¯/______________________
\_\
Old September 22nd, 2008, 07:14 PM   #3
jkellam is on a distinguished road
Just keep it close to the upper line and you will be fine
Old January 30th, 2009, 05:46 AM   #4
Look Ma! My First Post!
jeena is on a distinguished road
i think ,if u close that , it will fine for long life
Kit Xenon
Threads Similar to: oil control
99 Cobra 4.6 Oil Cooler machined hole porting Oil? ocJB3 99-04 3 January 3rd, 2011 06:31 PM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 01:17 AM
Code P1443 Evaporative Emmision Control System Control Valve jagstang96 96-98 10 September 5th, 2006 07:26 PM
Billit Oil Pimps vrs GT and Cobra Oil Pumps WAR-PARTY 99-04 2 August 22nd, 2006 12:55 AM
Purge Control Solenoid or Purge Control Valve fault kdevildog01 General Tech 3 July 17th, 2006 01:45 PM
