Where are YOU mounting your solenoids?
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > AutoLoc Power Accessories
Old June 2nd, 2009, 03:51 PM   #1
kris@thehoffmangroup is an unknown quantity at this point
I know you are going to say "In my door DUH!" But you don't HAVE TO mount your solenoid in your door. We recommend mounting the solenoids INSIDE your ride. No more having to make your door swiss cheese trying to find the right mounting location. The advantages of mounting your solenoid inside the cable are great. Easier to get to if you need to make an adjustment. No more worrying about your solenoids freezing in cold weather or moisture causing any problems.
It's simple to relocate or install your solenoid in the cab. All you need is our Advance Cable & Pulley System and about 30 minutes of your time to install.
The most common install is under the seat or in the kick panel. If you have more questions about relocating or installing your solenoids inside your cab please post your questions or PM me.
Threads Similar to: Where are YOU mounting your solenoids?
X brand Solenoids ? haveav8 General Tech 1 March 20th, 2009 01:36 PM
NX Stage 6 Solenoids MyGT General Tech 8 October 7th, 2008 02:54 PM
NX Stage 6 Solenoids MyGT 99-04 0 September 30th, 2008 04:42 PM
frying solenoids???? help onehot351 5.0 Mustangs 1 June 16th, 2008 11:32 AM
Who makes the best replacement solenoids catchtheroadrunner 2005 - 2010 3 January 1st, 2008 10:10 PM
