Discussing ProParts Spek Gauges Available at BMC Performance!!! in the BMC Performance Forum. Thought all you guys and gals out there looking for some gauges would really love ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2005 Mustang GT
Stock-13.420 @103.42
Thought all you guys and gals out there looking for some gauges would really love these!!
We are in the process of installing ProParts gauges in a few cars at the shop. We first saw these at PRI last year and several NASCAR drivers have switched to ProParts gauges instead of Auto Meter. After doing a bunch of research on them, we are really impressed with the quality and features, so we are switching to them in all our shop and race cars. Here is some info from the ProParts site: The Spek™ Boost gauge is electric and microprocessor based. The patented Wide-Angle Dial design creates the largest viewing dial ever mounted on a 2 1/16” gauge. High intensity LED technology and light distribution is designed for day or night driving with programmable dimmer setting for both Day/Night. Seven color programmable faceplate illumination in Red, Blue, Green, Orange, Yellow, Purple or White. Both the dial and pointer brightness are individually adjustable to match factory OEM gauges. Brushless stepper motor for an accurate pointer reading of a 280 degree full sweep analog readout. Gauges are programmed through patented water resistant stainless steel sealed command keys located on the faceplate for demanding environments. No control boxes or hand-held remote control needed. Peak playback value can be retrieved. High and Low lighted alert levels can be set with programmable outputs signal to activate relays or communicate to other SPEK controllers. Spek™ gauges come with a plug receptacle for connecting the sender wiring harnesses. Self diagnostics software will flash display if the sensor signal is lost. Features: *Brushless Stepper motor with full sweep 280 degree pointer. *7 color background setting with day and night background and pointer dimmer *Replaceable external MAP pressure sensor with temperature compensation. *Plug and Play wire harness for easy installation *Patented lighting delivers one of the largest and brightest displays ever assembled on a 2 1/6 inch gauge *Peak playback displays highest Boost level *Programmable output to control relays or communicate to other Spek controllers. *Available in Smoked or Clear Lens, Chrome or Black Bezel with White, Silver or Black display *Fits standard 2 1/16 inch ProPods mounting Pods, Dash Pod or universal #81102 steering column mount. *Easy to read Analog pointer (No flashing and blinking digital displays.) ![]() ![]() ![]() ![]() ![]() ![]() Here's a youtube video from NASACR performance on speed channel: Check them all out here: ProParts Gauges at BMC Performance |
Threads Similar to: ProParts Spek Gauges Available at BMC Performance!!!
| New Black ZR-1 Came by BMC Performance | BMC Performance | BMC Performance | 1 | August 29th, 2009 11:08 PM |
| What would YOU like to see from BMC Performance?! | Curt@BMCPerformance | BMC Performance | 0 | August 26th, 2009 11:28 AM |
| Howdy all from BMC Performance!! | Curt@BMCPerformance | BMC Performance | 2 | August 10th, 2009 08:21 PM |
| Welcome BMC Performance! | Administrator | BMC Performance | 4 | June 30th, 2009 09:07 PM |
| How to Contact Us at BMC Performance | BMC Performance | BMC Performance | 0 | June 24th, 2009 10:15 PM |
