Techco 100mm CAI w/ MAF for 2005+ Mustang GT
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > BMC / Speedlogix
Old June 25th, 2009, 04:12 PM   #1
2001 GT Vert / 97 Cobra
BMC Performance is on a distinguished road
Thumbs down
Check out Techco's 100mm Cold Air Kit w/ MAF for 2005+ Mustang GT
TECHCO designed this Cold Air Kit to be the highest flowing kit available. The cold air kit Air Filter Shroud contains a large volume area to fit the high-volume Conical washable/reusable Air Filter, Billet Aluminum Venturi with 100mm Inlet Orifice, Billet Aluminum 100mm Mass Air Flow Meter Housing, and high-flow 100mm Cold Air Inlet Tube. The result is over 80lb/min flow at 5volts with your stock (MAFS) Sensor (MAFS Curve provided with the installation instructions for Required Custom Tune). The Flow Bench tested design of the TECHCO 100mm Cold Air Kit provides airflow increases of up to 45% over Stock and outflows the Saleen 98mm (Rubber & Hard Tube). This Cold Air Kit fits both Stock and Saleen Series VI Supercharged S197 V8 Mustang applications. This Cold Air Kit was featured on the 720HP SMS 25th Anniversary Mustang.
Price: $469.88
To order: BMC Performance
Threads Similar to: Techco 100mm CAI w/ MAF for 2005+ Mustang GT
Techco ported S/C, CAI & tune...AWESOME! cdmsaleen 2005 - 2010 25 June 11th, 2009 10:36 PM
2005+ stock MAF acmillr 2005 - 2010 0 June 4th, 2009 02:22 PM
Steeda CAI and Techo 100mm MAF fastregalwe2 2005 - 2010 2 May 23rd, 2009 10:44 PM
Techco 100mm CAI chad05gt 2005 - 2010 2 December 22nd, 2008 06:23 AM
