BMR Launches New Product - 2010-2011 Mustang Handling A-arms (AA025, AA026)
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > BMR Fabrication
Old August 8th, 2011, 02:04 PM   #1
Authorized Vendor
BMR Tech's Avatar
BMR Tech will become famous soon enough
Talking
BMR Suspension
Handling A-arms for the 2010-2011 Mustang
Correct the suspension geometry on your lowered S197 Mustang with a set of Handling A-arms from BMR Suspension. Based on our well proven traditional A-arm design, these Handling A-arms feature ¾” taller ball joints to raise the roll center height on lowered vehicles for improved handling. The BMR Handling A-arms are constructed from heavy duty 1.25” DOM tubing and feature laser cut double-gusseted reinforcement plates. The non-adjustable A-arms (AA025) include a combination of low-deflection, internally-fluted, polyurethane bushings and fluted, greasable, Delrin bushings. The adjustable A-arms (AA026) include Delrin bushings and Teflon-lined XR series spherical rod ends with stainless spacers. The result is a high quality tubular A-arm that minimizes bushing deflection, reduces un-sprung weight by up to 11 pounds, and improves handling by reducing body roll. Installation time is only 3 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit BMR Suspension - The Leader in High Performance Suspension & Chassis, email sales@suspension.com, or contact them at BMR Suspension, 12581 N. US Highway 301, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
Kelly Aiken "The Ford Guy"
BMR Suspension Inc
kelly@bmrsuspension.com
813.986.9302
CLICK IF YOU LIKE BMR SUSPENSION
Old August 11th, 2011, 10:29 AM   #2
Authorized Vendor
BMR Tech's Avatar
Here are the arms, now listed on our web-site!
BMR 2010+ Mustang Front Tubular A-Arms, 19mm Tall, Non-Adjustable, Poly-Delrin
BMR 2010+ Mustang Front Tubular A-Arms, 19mm Tall, Adjustable, Rod End-Delrin
BMR Suspension Inc
813.986.9302
Old August 19th, 2011, 01:25 PM   #3
Authorized Vendor
BMR Tech's Avatar
For those of you that are wondering about the roll center, and exactly what is affected when lowering your car...
When you lower the car, your chassis drops......however the spindles, and mounting points do not. The connecting points between the chassis/K-Member....and the spindle/strut/spring assembly are now placed at drastically different angles. The A-Arm will have an upward angle towards the wheel.
When you install a taller ball-joint, you are now effectively lowering the actual A-Arm back down, which improves the overall geometry and handling capabilities of the front suspension.
Hope that helps!
BMR Suspension Inc
813.986.9302
Threads Similar to: BMR Launches New Product - 2010-2011 Mustang Handling A-arms (AA025, AA026)
BMR Launches New Product - Upper Control Arm for 2011 Mustang (UTCA030) BMR Tech 2011+ 12 April 12th, 2011 12:21 PM
