1965 granny mobile
stock 6 n/a
200 6 cyl carb ?
I have a 65 mustang with a 200 6 cylinder. anyways the carb is junk. i would like to replace it with a bigger better one etc.. but u cant replace the intake because its built into the head . any ideas ?
Priest of the Car Gods
Yeah....
I haven't done too much research into this, but my understanding is that you're pretty much screwed, lol. You can mill off the intake manifold and have a different one put on there that will allow for a better carb setup (triple weber sidedrafts would be cool), or you can go to fuel injection (maybe). You might also be able to find a different head for the motor (maybe off a 250 or a 300). Good luck with it man.
carb
go to www,classicinlines.com.they offer an adapter plate to put a 2 v carb on your engine.you can do anything if you want to.
i sixing 200 six with 300 hp. Last edited by 460brevill; January 18th, 2010 at 12:03 PM. |
2001 GT
If you use the clifford 2v adapter you can get the Holley/Weber 2v carb from langdon's stovebolt.
The CI adapter is for carbs like the Holley 350cfm 2bbl.
use the 250 head.has a bigger log runner for more air flow and bigger valves.76 granada 250 is good.300 will not work.
i sixing 200 six with 300 hp. |
1966 Mustang
with the 250 head, don't you have to perform some mill work? I have heard that it involves a lot of machining to get it to work properly.
no muss no fuss.direct bolt for bolt hookup.same bolt pattern and torque.
1965 granny mobile
stock 6 n/a
thanks
i like the idea of using the adapter plate thats cool. and thanks for the site. but next step is what carb should i use with the adapt.? and where should i get it ? i know u can only fuel an old six so much before u defeat yourself . and i have no clue what i should be looking for. i have never tried to make a 6 cyl. "run good" before. hey any ideas are useful. thank you.
2001 GT
If you use classic inlines adapter go with a Holley 350cfm 2bbl.
If you use clifford adapter go with Holley/Weber 2bbl.
1966 Mustang
Ok, 6 cylinder performance guys. So far, I have a clifford header leading to 2.5'' exhaust with flowmaster 40 series mufflers, flexalite fan (for the hot summers), and pertronix ignition. I just spent a sh*t ton of money on a ponycarbs Autolite 1100 to make the car run smoothly. I am seriously considering throwing on the 250 head (I found one in really good shape) and switching to a two barrell carb. It is worth it? Will drivability suffer? I just want a car that is fun to cruise in, but has enough power to get down the interstate with ease. Let me know what you think. Thanks in advance.
Mike |
go to the site i listed ABOVE.get a cam and use the 350cfm BA MUSTANG suggested.you will see a big diff.
1965 granny mobile
stock 6 n/a
i also have a 289 under the bench. but i have been told the suspension and the 4 bolt axels can't take the stress ? as far as the weight the v8 can't weigh but a couple hundred pounds more . but ive been warned so there must be a reason. and off topic maybe replacing the 6 cyl. would take from the value. i dont know. just want a more responsive ride. so give me some ideas. thanks.
1966 Coupe
the i6 and v8 have different steering components, including spindles, tie-rods, centerlink, idler and pitman arm. The coil springs for the v8 are beefier to hold up that motor, and the 4-lug axle and brake system is different. And the Rear end is different.
You CAN keep the tie-rods, centerlink, idler and pitman IF you go with the CSRP Swap kit #2 from discbrakeswap.com. that will upgrade you to beefier spindles, with 5 lug Disc brakes. You will still need to replace the front springs and the rear-axle, though. The Upper and Lower control arms for the 6 cylinder and V8 are the same, so you can leave those alone...though if they are older, they might require some inspection and freshening anyway. I recommend a new LCA, Upper Ball Joint, and Moog UCA Shaft Kit. you're probably looking in the 1k - 1500 range BEFORE you build and install the motor, depending on how well you source your parts |
1966 Mustang
so how big of an increase in power am i going to see by simply replacing the stock head with a 250 head? and will this run ok with the stock carb and my previously mentioned mods?
it will run fine.dont look for a big increase without carb.
Do you have to machine the intake manifold before using an adapter plate?
"The man who smiles when something goes wrong is the one who has someone to blame" |
Threads Similar to: 200 6 cyl carb ?
| 0-200 | White Thunder | The Clubhouse | 4 | July 2nd, 2008 01:46 PM |
| Most HP from 4 cyl | Brenda | 2.3 Mustangs | 64 | November 11th, 2007 08:46 AM |
| 4 cyl maf sensor or 8 cyl? | Darrellx14 | 5.0 Mustangs | 12 | January 11th, 2007 10:15 AM |
| 4cyl to 8 cyl ???? | doorvip | 5.0 Mustangs | 2 | December 18th, 2006 07:23 PM |
| Looking for someone who has actually done a 4 cyl-8 cyl swap | OTreborO | 5.0 Mustangs | 0 | August 17th, 2006 11:16 AM |
