Starter issues
Old January 2nd, 2009, 09:47 AM   #1
coolhand is on a distinguished road
Starter issues
I replaced the 289 in my 65 with a 351 w..using a t-5.
My starter will not go far enough in to turn the Flywheel?
Do I need a 351 starter?
Old January 2nd, 2009, 10:14 AM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
What year bell housing did you use?
What year is your 351W?
Witch Flywheel you use 157 28oz or the 164 50oz?
351W made from 1981 newer use a 164 tooth 50 oz fly wheel.
Im betting you used a 157 tooth flywheel in a 164 tooth big bell housing.
Make sure you use the correct set up 157 tooth flywheel for a 157 tooth bell housing.
And 164 tooth flywheel in a 164 bell housing.
and if you mixed the 2 you can order a 157 50oz flywheel or a 164 28oz flywheel.
Old January 2nd, 2009, 06:10 PM   #3
answer- Used a 65 model housing, a 65 flywheel...
Old January 3rd, 2009, 01:10 PM   #4
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
What year is the motor?
A ford Starter for the small block 289- 351W is the same from 65-75 just there is 2 of them 1 for a Auto, 1 for a standard. This year range differ very little.
Old January 5th, 2009, 07:04 AM   #5
The 351 is a late model..rollor cam engine.
Old January 5th, 2009, 10:42 AM   #6
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
you will need a 157 50oz fLywheel or the motor will vibrate like a bitch.
Heavy-Duty Flexplate
Ford SB 1981-1996
302W/351W
C-4 10.5 Pattern
O.D. 13.30''
157 Teeth
50 oz Counterweight
Threads Similar to: Starter issues
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
help with starter kuskye25 5.0 Mustangs 5 March 16th, 2008 11:07 PM
starter HELP!!!!! dcrow 99-04 8 October 2nd, 2007 09:28 PM
starter help please??? lwhitetrash88l V6 Mustangs 2 June 1st, 2007 12:18 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
