LinkBack (1) | Thread Tools |
#1
how hard to install 5.4l svt
just asking if anyone has seen or installed a 5.4l svt in an 60's model stang it is a 302 so it should fit fine with a little mod but not sure on if any major size diffs any were in the new motor fyi it is 98 lighting 5.4l going into a 67 or 68 stang,any comments are very apreciated,thanks
1969 Mustang Mach 1
7.324@94.61 N/A
A 5.4 is is not a 302, but to answer the question, yes it will fit. It takes some fabrication, and just barely squeezes in because a modular motor is considerably wider than a pushrod motor. There's a guy on here who has done it that can give you more info, and I'm sure he'll chime in tomorrow.
![]() ProSystems Aeromotive TFS MSD Bullet Induction Solutions PA Moser |
So What Would A 5.4l Be Considerd A 331? I Am More Familar With Chevy Not So Much Ford But Have Always Loved The Mustang And Am Very Serious About Making This Happen There Are Two Frames That I Am Lookin At A Fastback And A Gt Both Look The Same As Far As Under The Hood ,fender Walls Will Definitly Need To Be Cut As Well As Like U Said The Firewall,i Am A Novice As Far As Main Engine Work Goes But Understand This Will Definitly Take A Good Bit Of Time To Complete,gettin Older And Whanting To Find Anew Hobby Already Have The Engine And Trans Just Need The Car,thanks
1965 Coupe
check out the february issue of modified mustangs and fords, the mustang on the cover has a 5.4 supercharged motor in it.
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Welcome to MM Forums
Here is our 4.6 in a 1968. To do a 5.4 it is 3" wider than a 4.6 2" taller than a 4.6 for a 5.4 You have to remove the shock towers and move the master cylinder out 3 " and rasie the hood Here is a link to our 5.4 fabrication for the Python 5.4 Here is more photos of the 4.6 Anaconda
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; January 6th, 2009 at 10:06 AM. |
#6 | |
1969 Mustang Mach 1
7.324@94.61 N/A
A litre is roughly 61 cubic inches, so a 5.4 is somewhere around 330 cid. The numbers you are talking about are old school engines that aren't produced by the factory anymore.
Ok So You Are Saying That The Shocks Dont Have To Move Only The Shroud Around Them Correct, So I Would Just Cut Away The Round Part And Make It Flush ,right Mustangone?
Lost in the 60's
12.6 @ 114.3
Yes, You have to take out the shock towers out, and go to a Mustang II style front end.
If you look at the photos I posted 50 photos showing how to do it. |
90 mustang notchback
Not to thread jack Mustang1 the Python is sick.I didnt know about you shop here in oklahoma. Are you taking those cars to shelby meet
306 Turbo Notch D&G Tuned
Lost in the 60's
12.6 @ 114.3
Yes, we will have it at the Mid America Shelby meet in Tulsa in June
#11 | |
2007 Mustang GT
easy fit
Totally Turbo
Hey Just Wondering If Anyone Has Any Pics Of There Motormount Conversions Just To Get A General Idea Of What Its Going To Look Like,thanks
#13 | |
1969 Mustang Mach 1
7.324@94.61 N/A
A 5.4 is not a 351. A 5.4 is a modular motor that is nothing like a convential 351. The OHC makes the physical deminsions MUCH larger across the heads than a pushrod motor. Like i posted earlier, 1 litre is roughly 61 cu in making the 5.4 around 330 cid, but modulars are a whole different game than a pushrod motor. It will not fit without major modification. You have to put a Mustang II front end in it, which is wayyy more than motor mounts.
![]() ProSystems Aeromotive TFS MSD Bullet Induction Solutions PA Moser Last edited by 69fastback; January 7th, 2009 at 04:10 PM. |
1969 Mustang Mach 1
7.324@94.61 N/A
A Mustang II front end is looks something like this and requires some modifications to put it.
#15 | |
Lost in the 60's
12.6 @ 114.3
Ahhh.... We are talking a about a 5.4 Mod Motor like in a 2008 Cobra not a 1969 - 1995 351 windsor This is a 5.4 Motor ![]() Here is what our motor mounts look like.
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; January 7th, 2009 at 08:10 PM. |
The Engine That I Am Installing Is A 5.4 Svt Lightning Engine With Sohc The Cobra Engine Is A Little Different ,i Measured The Engine Today It Will Fit With Removing The Shock Towerswith Just Enough Room To Get My Hand Down The Side Lol,i Found A 71 Mustang Front End For 350.00 I Havnt Seen It Yet Only In A Pic That Will Work Right Fastback?
Sorry Typo A 74 Mustang Front End I Found For 350.00
Lost in the 60's
12.6 @ 114.3
We used the 5.4 DOHC setup.
This is the setup we use. For everything to install free shipping WELD-IN KIT INCLUDES: Frame reinforcing plates & Inner Fender Panels Crossmember Upper A-arm & Stock Mounting Tower Urethane Bushed Tubular A-arms TCI Custom Spindles Steering Arms Power Rack & Pinion Coil Over Shocks 11' Disc Brakes w/ OEM calipers $2450.00
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; January 8th, 2009 at 12:13 AM. |
nice setup mustangone.when i finish the 66 vert i am doing now ,i may get with you on that unit for my next build.a 66 one seater like the 56 t-bird.
i sixing 200 six with 300 hp. |
in this form section go to ok I'm doing it and you will see a dohc 5.4 shelby engine and 6 spd setup in a 68 convert. I can't post pictures here for some reason but the mustang 2 setup is not the way to go you loose alot of strength in the front this car will be is vegas in april going on the tour to ala. if you email me I can send more photos and also tell you how to do it. It is NOT AN EASY sway and does require alot of engineering to pull it off right. We have six figures in this car already and it isn't finished yet. WE just finished a 40 merc with the same drive train. It takes around 20 grand to hook up the motor and make it run. Ford has just come out with a wiring kit for them but it is 1800 alone email me and I will help you out. RED
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/104192-how-hard-install-5-4l-svt.html
| Cobra Motor - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | December 13th, 2009 01:25 PM | |
Threads Similar to: how hard to install 5.4l svt
| Tint hard to install? | Novanutcase | 99-04 | 18 | July 7th, 2009 11:03 AM |
| how hard will this install be... | texas_mustang | 2005 - 2010 | 47 | May 27th, 2008 09:27 AM |
| how hard is it to install a cam? | 91cobra5.0 | 5.0 Mustangs | 17 | February 17th, 2008 06:06 PM |
| How hard of an install?? | AnglicoGT98 | 99-04 | 14 | January 24th, 2008 11:37 PM |
| Focus SVT Fuel Pump install | gsjohnson | 99-04 | 5 | September 16th, 2007 03:40 AM |
