autometer gauges
LinkBack (1) Thread Tools
Old January 11th, 2009, 12:42 AM   1 links from elsewhere to this Post. Click to view. #1
1965 Ford Mustang
01dutchGT is on a distinguished road
Send a message via AIM to 01dutchGT Send a message via Yahoo to 01dutchGT
autometer gauges
I have a electrical oil pressure and water temp gauge. Have everything finaly hooked up but the gauges arent working right. At first the gauges would only light up and not show any readings. Then i made sure my grounds we ok and found the they werent on a good enough ground so i switched the grounds and then the gauges shot strait to the right and stayed. Why is this? Can someone help out.
Thanks
2001 mustang gt 5 speed
Full bolt ons with 4.10 gears.
1965 Mustang
302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter.
In the process of restoring it...
Old January 11th, 2009, 12:23 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
You need to check were you have you wires hooked up.
S = Source aka the sending unit of that guage.
12+ = Switch 12 volts , I like the post off the back of the Ing Switch.
G = Same ground that is behind you instrement panel that all you stuff is grounded at
Lights = goes to the Blue w/Red stripe wire. there is a triple plug behind your insterment panel.
Old January 11th, 2009, 09:44 PM   #3
1965 Ford Mustang
got it all worked out. Had a short in the power source. Just bad connection I did.
1965 Mustang
Old January 11th, 2009, 11:24 PM   #4
Lost in the 60's
MustangOne's Avatar
12.6 @ 114.3
Good Job...
Old January 12th, 2009, 01:05 AM   #5
1965 Ford Mustang
Now just have to figure out how to get the old oil pressure sender out. Its being a pain in the ass.
1965 Mustang
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/105038-autometer-gauges.html
*Clix This thread Refback February 15th, 2009 01:58 PM
Threads Similar to: autometer gauges
Autometer gauges 01dutchGT Classic Mustangs 13 October 18th, 2008 09:07 AM
Really Disappointed with autometer gauges! 03_StangGuy 99-04 18 September 24th, 2008 02:47 PM
