Ignition Problem with my 67
I dont get any power to my Red/Blue wire to the "S" on the starter soleinoid when i turn the key to the start position. I have power to the Brown wire to the "I" terminal once i turn the key to the run position though. The car wont turn over at all and i have a new Ignition switch and Starter soleinoid. If i put the Brown wire on the "S" then it tries to start. But i just cant figure out why the Red/Blue wire doesnt get power no matter what i do. Any suggesions?
most like the nutral safety switch.
i sixing 200 six with 300 hp. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
The Red/Blue stripe starts at the Ing Switch, Then at the fire wall if it is a automatic car it goes down to the nutreal safty switch on the side of the trans. in this case it will on start in park or neutral, the comes back up to the start sol.
Manaul car the neutral switch is bypass at the fire wall. |
Ignition
I dont have a neutral safety swicth just yet. I just ordered one though. I saw online how to bypass the neutral safety switch by just using two peices of wire in the connectors so thats what i did. I take it that doesnt work like they say it does?
#5 | |
Lost in the 60's
12.6 @ 114.3
Yes it does, Just look at it there are 4 wires the 2 red/blue stripe and 2 black with red stripe "Backup lights". Use a test light on the female of the Red w/blue it should have power when you hit the ing to start. If it does then jump it to the other red w/blue If has not power it has a problem under your dash. |
Got it, Thanks!!!!! Got the wife out there to turn the key while i checked wires out and found it. It started right up after that.
Lost in the 60's
12.6 @ 114.3
Go to hear... Any time we can help
Threads Similar to: Ignition Problem with my 67
| Ignition problem | JonnyStang85 | 5.0 Mustangs | 5 | December 4th, 2008 05:43 PM |
| Ignition timing problem..... | 93mustank | 5.0 Mustangs | 18 | December 2nd, 2008 09:28 PM |
| ignition problem with my other vehicle | 92_LX_5.0 | 5.0 Mustangs | 2 | November 8th, 2007 10:15 PM |
| is there anyway to get away for the ignition problem | gordon norris | 5.0 Mustangs | 4 | February 19th, 2007 09:34 PM |
| Ignition problem? | 86blkmustang | 5.0 Mustangs | 15 | February 7th, 2007 08:55 PM |
