14.12
went for a ride
Today was my first drive in the car since i bought it. Here are the "bad" things that i noticed:
1. Car is extremly hard (almost imposible) to get into 1st gear. 2. When i let off the gas pedal, the accelarator butterfly valve on the carborator stays open. 3. Rear shocks/springs are shot completly. 4. There is cold air coming from somewhere by the pedals. (it was 25 degrees outside) 5. Brakes suck big time (needs a disk conversion) 6. Belt is wining like its about to snap (its a brand new belt) I would appreciate it if you guys have any idea on how to fix all of that.
Let it rippp...
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
You have the one that has to be stop to get it back into first.
![]() Carb just sucks on the one. ![]() Shocks are easy and cheap, Monreo gas matics $17 ![]() Look at the seal around the accel rod , it is cheap fix. ![]() Brakes sucks on that car. ![]() Need to get new belt with correct pitch. it to small in width. ![]() Good Luck |
2001 GT
There is a vent under the dash area that might be open. My belt used to do that after we put a new alternator on. Just tighten it up real good. Check your pads, brake fluid on for the brakes. Also maybe think about upgrading to a dual master cylinder, if you don't go disk. My old carb had that problem. I called it cruise control since it would keep me at the same speed.
So yours doesn't have 1st synchronized then. My grandfathers 66 sprint does
14.12
As far as the transmission i think that i will take it to a shop and see what they say cuz i think that it is a bit beyond me.
The carburator i have a spring on order to see if that is gonna fix it. Shocks i need to replace - u r right they are cheap and i think that i will be able to swap them out without a problem. For the cabin insolation, i have all the seals and they seem to be ok. I just didnt see any vents on the firewall. Maybe i need to look more carefully. But my stearing column seal is good, accellarator seal is good. and i cant see any light coming when i open the hood in the sun. Brakes like i said i know that i have to swap What do u mean to check if this is the correct pitch. I dont know how to tell. the belt is very tight no slack what so ever. Thanks guys
Let it rippp...
Lost in the 60's
12.6 @ 114.3
The shape of the v belt well it is in the shape of a V ...
The point of the belt is to narrow and bottems out before the sides of the belt can bite on the sides. You need a belt with a fatter bottem |
Threads Similar to: went for a ride
| new ride | TORCH | Pictures | 22 | November 3rd, 2008 01:48 PM |
| my new ride.... not | MustangMatt96GT | The Clubhouse | 10 | June 22nd, 2008 03:26 PM |
| $300 In Pimpage For Your Ride - AM BLOG Pimp Brick's Ride Contest! - June 2008 | AMNick | American Muscle | 4 | June 16th, 2008 03:29 PM |
| New ride. | 707Stang | The Clubhouse | 21 | January 3rd, 2008 05:08 PM |
| Better Ride????? | Boris | General Tech | 6 | September 5th, 2007 08:53 PM |
