1969 Mustang Mach 1
7.324@94.61 N/A
Burning oil
My car is using a lot of oil. By a lot, I mean about 1 quart every 500 miles, and it doesn't leak at all. After the engine was built, it was only driven about 50 miles in the first two years, and now it's driven on a pretty regular basis. It has apprx 20,000 miles on it, and it's smoking a little, but nothing real bad.
With the large oil consumption, I decided to run a compression check, and it broke down like this. #1: 130 #5: 130 #2: 130 #6: 130 #3: 130 #7: 130 #4: 125 #8: 130 I don't think you could ask for much better than that. Could the valve seals possibly be leaking so bad, as to cause 1 quart every 500 miles to disappear? I'm sure they're leaking some, because of the puff of smoke it blows on start up, but there isn't smoke while driving. It smokes some under hard accelleration, and when you let off the gas, but it's not terrible. Any thoughts?
![]() ProSystems Aeromotive TFS MSD Bullet Induction Solutions PA Moser |
have your taken the intake off lately? i know that causes massive oil loss. stupid question none of it is leaking right?
#3 | ||
1969 Mustang Mach 1
7.324@94.61 N/A
No leaks
it most likley the valve seals,they can be replaced without pulling the heads.that is where i would start.
i sixing 200 six with 300 hp. |
1966 Mustang Convertible
Combo valve seals and/or valve guides. Seals can be replaced with head still on, valve guides require a valve job with heads off.
1969 Mustang Mach 1
7.324@94.61 N/A
That just seems like a lot of oil to be going through the valve seals, but I guess it's a cheap easy thing to try first.
Ya I would say start with the valve seals. I also read that:"After the engine was built, it was only driven about 50 miles in the first two years" This could also be a reason for the problem?
I also read an article in a technical magazine a while back that said: "High operating temperatures cause lower grade materials such as nitrile to harden and become brittle over time. Eventually, this can lead to cracking, loss of oil control and seal failure. When a valve stem seal loses its ability to control the amount of oil that enters the guide, it can cause a variety of problems." Good luck.
1966 Mustang Coupe Ford Racing 5.0 HO Roller Motor/B303 Cam/1.7 RR TFS TW 205 Heads/Ceramic Coated Tri-Y Headers Edelbrock Performer RPM/Holley 650 DP 8 qrt Milodon oil pan/Griffin aluminum radiator Mallory Distributor/MSD/Holley Electric Fuel Pump 2.5" Exhaust with H pipe/2 chamber Flowmasters Auburn 3:55's rear/Aluminum drive shaft + loop SSBC disc brakes/C-4 wTCI 2800 15x6/15x7 Torque Thrust D's BFG Drag Radials Fiberglass Shelby hood/frt valance/trunk/bumpers |
Threads Similar to: Burning oil
| Burning Oil | ddashtrois | 99-04 | 7 | July 8th, 2010 04:24 PM |
| Am I Burning Oil? | PiggySmallz | 2005 - 2010 | 55 | December 28th, 2008 10:52 AM |
| burning oil??????? | 5LBennett | 5.0 Mustangs | 20 | July 4th, 2007 12:34 PM |
| Burning Oil | thewayshemoves | 99-04 | 4 | December 27th, 2006 12:25 PM |
| Burning Oil | terribleonexx88 | 5.0 Mustangs | 11 | November 13th, 2006 11:45 PM |
