Help in getting Engine Started
Old January 9th, 2007, 08:25 PM   #1
Look Ma! My First Post!
jei3270 is on a distinguished road
I have a 66 Mustang GT that seems to have a spark or ign. problem. The car is a 289 V8 GT automatic. Recently while driving the car just stopped, as if it were out of gas, which it was not. The car would not restart even with the assist of carb. spray. I have replaced the coil, the dist. cap, the fuel filter and the fuel pump. The car will turn over but not fire. The Dist. has the new electronic ignition system rather than points and condenser.
Any Suggestions on trouble shooting?
Old January 9th, 2007, 09:12 PM   #2
SemperFi is on a distinguished road
Could be several items. If you've switched the points/condensor to electronic ignition & it died while running, sounds like it might be a bad ground or wire connection. There is also a spark modulator but they normally fail after car has shut off but i suppose it's possible that it could fail anytime. Start with the basics - trace spark starting from coil to plugs. Do you have spark at the plug? Where do you lose spark?
SemperFi - God, Corps, Country & Mustangs.
Old January 9th, 2007, 09:17 PM   #3
My67_fastback's Avatar
My67_fastback is on a distinguished road
Send a message via AIM to My67_fastback
yes, take out the plugs one at a time and lay them on the block away from any other wires, just on bare metal, or hold them by the wires and put them up against some ground somewhere else and crank the engine. if the spark jumps, then its not ignition (for that cylinder anyway). do this to each one. if there is no spark, then pull the plug wire and test it with a dvom (digital volt ohm meter) for resistance to see if the wire is bad or not. work from there. replace the plug if you want to also.
TO: Ricers-
1) there's no replacement for displacement
2) my lug nuts require more torque than your engine makes
3) a light car doesn't excuse a weak engine
4) a bottle of pepsi has more liters than your car
eating rice builds muscle
Old January 10th, 2007, 07:42 AM   #4
Fastback GT's Avatar
Fastback GT is on a distinguished road
are you getting power to the coil?
Thanks Bill
My Lug Nuts Have More Torque Than Your Honda !!
Old January 10th, 2007, 02:30 PM   #5
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
i've been having the same problem with my '64 1/2
after a while of trying just about everything, i pulled the spark plugs out and they were wet which kept it from firing.. replaced all 8 and it ran like new!
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old January 12th, 2007, 11:00 AM   #6
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
14.65 @ 99.83
707Stang is a jewel in the rough707Stang is a jewel in the rough707Stang is a jewel in the rough
Umm just a thought but have you checked the timing? and along with that did you tighten your distributor down, i say this cuz i did it before and it cost me a muffler. OOPS!
Old January 12th, 2007, 07:51 PM   #7
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Threads Similar to: Help in getting Engine Started
How my day started WAR-PARTY The Clubhouse 5 September 28th, 2007 02:25 AM
project has been started guys!!! droppedbass87 96-98 19 August 12th, 2007 12:18 AM
Started off the week with a bang White99stang The Clubhouse 21 July 26th, 2007 04:16 PM
forum started beheivjer The Clubhouse 8 February 28th, 2006 08:20 PM
331 started missing today groundpounder 5.0 Mustangs 6 November 11th, 2005 01:18 PM
