1967 Mustang Coupe
Ignition Swap
Getting ready to do my DSII swap on the mustang. Been running like crap and my MPG suck. So I am performing the swap over the weekend and hope it helps. Will keep you guys updated.
Dizzy - $50 Module - $25 Rotor - $4 Cap - $9 Wireset - $22 Some extra pieces - $13.50 Still waiting on the Cap adapter to get here. That will be around $11 and I also need some vacuum tube for the vacuum advance and that will probably be $5. Will end up spending about $142. Few other parts I have/are coming - New rear shocks($30) and chrome monte carlo bar($25 shipped).
why not use the standard cap,rotor and wires?you still get good fire without all the bulk.
i sixing 200 six with 300 hp. |
1967 Mustang Coupe
Didn't know I could use the cap, rotor, and wires I have now on the new dizzy.
pic?? i am running ds11 on some of my cars with the old style chrysler module.works great.
i sixing 200 six with 300 hp. Last edited by 460brevill; February 26th, 2009 at 04:43 PM. |
1967 Mustang Coupe
Using this and Duraspark blue grommet module.
you can use the stock cap rotor and wires.
1967 Mustang Coupe
Well I have everything supposedly wired correctly. But I am not getting any volts to the starter relay even though the battery reads 12V. Did I fry my relay? Battery cable is hooked up.
make sure little wire is on proper post and check neutral safey switch.
1967 Mustang Coupe
I have a manual. I had 1 wire wrong. Going to run another wire and put it where it should be.
1967 Mustang Coupe
Well we finally got it started after 2 days. Had to get a new coil since I burned up the old one. That is 2 in less than 2 months.
Never will I do this kind of swap again to much of a pain for me.
i could have set you up with a complete wired kit if i had known you needed it.one wire hookup.
1967 Mustang Coupe
I won't be needing anything for it anymore. Made the decision yesterday after breaking down again it was time to sell. I'm staying with the mustangs though. Looking at 99-04 mustangs. Need a dependable DD. will get another classic after college.
I've broken down about 10-12 times now.
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
I Feel your pain...Good Luck on the hunt for your College ride. |
1967 Mustang Coupe
Not in college yet. I'm a junior in HS, but this will definitely be my college ride. Already have plans for mods.
what broke?
1967 Mustang Coupe
Burned up another coil. Also battery is bubbling so we think voltage regulator is shot also.
So far it has burned up a Flamethrower II coil, MSD Blaster 2 coil, and old original looking coil.
I plan to use a proform hei (already have it). Have you given any thought to it?
Bill |
1967 Mustang Coupe
I just put in something similar to the HEI setup.
Lost in the 60's
12.6 @ 114.3
How many volts are going to you coil? it needs to be around 9V sounds like you are getting 12V or more . You might need to add a balast resistor in line to your coil.
1967 Mustang Coupe
In the swap it said it needed 12v. It was having 15V+ when it blew both coils over the weekend.
Classic Inlines The swap made no sense to me and my dad. We rewired it with the resistor attached and we are getting around 14V max now to coil. Gone 2 days without burning up a coil. The mustang just sits now. Dad bought a newer truck and I got his so I am not driving the mustang anymore.
Threads Similar to: Ignition Swap
| need help with ignition | samuel642000 | 5.0 Mustangs | 0 | February 12th, 2009 12:04 PM |
| the best ignition for me? | 5litercobra | 5.0 Mustangs | 4 | July 9th, 2008 08:59 PM |
| Ignition on an 06 | bwinter1980 | 2005 - 2010 V6 | 6 | May 29th, 2008 04:22 AM |
| MSD Ignition Or Crane Ignition | jg347stroker | 5.0 Mustangs | 0 | December 2nd, 2007 11:05 PM |
| ignition | theodoor24 | Classic Mustangs | 4 | March 30th, 2007 11:37 PM |
