Top End vs Bottom End
I am trying to get my motor build planned out and would like some helpful comments. 68 coupe with original 289 2v. I am looking at a top end build kit from Summit. My question is can I keep the bottom end stock or should I build it up also.
Trick Flow Specialties TFS-K514-360-350 - Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L - summitracing.com Eagle Specialty Products 14003-030 - Eagle Competition Rotating Assemblies - summitracing.com Thanks ahead for your wisdom, Mike |
Haven't run it
Unless you are planning on going EFI I wouldnt buy that TFS kit because you are buying extra stuff you dont need (The upper intake). Just get the heads/rockers/cam and save you some money. If the bottom end has never been refreshed I would go ahead and build it at the same time if you have the cash...
#3 | |
all the extra pressure on top may kill the bottom.
i sixing 200 six with 300 hp. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
If you going to keep stock bottem end I would look for 58cc heads not the 61cc heads.
That way you can bump the compression up a little. But if you go the rotating assembly you go with flat tops and stay at 10.0:1 and keep the 61cc heads
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; March 12th, 2009 at 11:07 PM. |
Haven't run it
my EFI setup the wires and harnesses werent actually too bad at all - I had about 3 main wires to hook up... of course there are a few odds and ends that have to be done that get kind of time consuming and costly - I ended up nickle and diming myself to complete it
you might as well freshen up the engine all the way,do the top and bottom end.
1988 Notchback
11.19 @ 122mph N/A
I'd freshen the bottom end with some better rods and pistons for sure. Then have the rotating assembly balanced. Then I would go with a set of AFR 165 heads and one of the Comp Cams XE cams. A Holley Systemax is an awesome intake for EFI applications and you could probably find these parts cheaper than what a Trick Flow kit cost. If you wanted to stay carb'd, I'd go with a Edelbrock Air Gap intake manifold and a Holley or Demon style 650cfm carb.
Threads Similar to: Top End vs Bottom End
| Bottom End | bartee25 | 99-04 | 4 | September 9th, 2008 01:10 AM |
| Forged bottom end? | ArmyChargedGT | 99-04 | 13 | March 4th, 2008 07:57 PM |
| is this a good bottom end?? | lilmarc1988 | 99-04 | 5 | January 23rd, 2008 05:34 PM |
| What's The Bottom Line On The Bottom End? | SKRAPR | 2005 - 2010 | 48 | November 25th, 2007 11:38 AM |
| How Much HP On Stock Bottom End | 5litercobra | 2.3 Mustangs | 5 | November 13th, 2007 02:55 PM |
