power steering in a 72
since the 72 im looking at has no power steering i was checking out thisVariable Pressure Pump, but what else will be needed.
my ninja
why all the trouble?they steer pretty good as is.
i sixing 200 six with 300 hp. |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
That is true.
But if I was going to add power steering to a 72 I would go to the local napa and get a 72 Powersteering pump $79 72 powersteering box $195 72 pressure and return hose $80 for both then get a pump braket for the motor you have. |
1972 Mustang Convertible
I'm all over that......thanks, Todd.
My '72 convertible is a bitch to turn in a tight parking lot. Tony Rumore Tromix Corp |
You also need a two or three groove crank pulley and a two groove water pump pulley. The early crank pulley's have three bolt holes, the 72 will have a four bolt pulley. I believe they changed from 3 to 4 bolts in mid 1969. Of course there are plenty of 3 hole pulleys available, but the 4 hole units are much harder to find. There is also an in-line fluid cooler as well.
Tony Last edited by TonyRumore; May 31st, 2009 at 11:24 AM. |
Threads Similar to: power steering in a 72
| power steering gone | mm49271 | V6 Mustangs | 1 | June 15th, 2008 01:08 PM |
| Power Steering.. help! | Reset | 99-04 | 1 | September 9th, 2007 11:54 AM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 08:24 PM |
| power steering | terribleonexx88 | 5.0 Mustangs | 4 | December 27th, 2006 07:50 PM |
| Power Steering?? | RedHott66 | V6 Mustangs | 2 | December 22nd, 2006 06:17 PM |
