Discussing Removing Old A/C in the Classic Mustangs Forum. Since I have bought my 70 three years ago I have had the factory A/...
Old January 16th, 2007, 07:12 PM   #1
CR70fastback's Avatar
Removing Old A/C
Since I have bought my 70 three years ago I have had the factory A/C in it is not hooked up and needs to be hooked up correctly to work. Is it worth keeping under the hood? Or is it better to just remove it box it up and throw it in the corner. Would removing it help preformace at all or would it hurt the value of my car.?...
Any thoughts................
Old January 16th, 2007, 09:10 PM   #2
I yanked mine out but only b/c it didnt fit. Depending on how much you need to fix (condensor, evaporator, compressor) and how much your willing to spend is all up to you. Your performance will be slightly increased anywhere from 5-8 hp, depending on the compressor size. Your value will be compromised slightly but realistically most people throw in a reproduction a/c anyways seeing as it cost more to salvage the original.
Old January 17th, 2007, 03:47 AM   #3
Thanks for the input I think I am going to have it taken out and get my motor re tuned. Think it will help gas milage?
Old January 17th, 2007, 02:28 PM   #4
I'm Hella From Nor*Cal
707Stang's Avatar
2008 GTI
blank
I think it will because you are removing drag from the engine, in that it doesn't have to strain as hard to turn that compressor which god only knows how well it turns anymore. Plus like stated earlier you'll be freeing up a couple ponies too. i ripped mine out a couple engines ago so, yeah. just my to cents.
GIAC Stg 1 Tuned, 3"TBE, Forge DV, Neuspeed P-Flow CAI, Neuspeed IC Noise pipe delete.
The Curse: 600 CFM Edelbrock, Hooker headers, Pertronix flame thrower dizzy, Accel coil, GT40 heads, 5.0 h.o,Super 44's
MM Four Banger Club: Founder
Old January 17th, 2007, 02:33 PM   #5
Is there anything tricky about removing one?
Old January 17th, 2007, 10:27 PM   #6
707Stang's Avatar
2008 GTI
blank
No not really just remember to plug up the the two pipes comin out of the fire wall and you prolly will be losing a belt too. Cuz when she ran, my baby was only had two belts driving everything. Good Luck dude!!
Old January 18th, 2007, 02:38 AM   #7
thanks man
Old January 18th, 2007, 06:19 PM   #8
707Stang's Avatar
2008 GTI
blank
Sure thing!
Threads Similar to: Removing Old A/C
Removing a decal what is the best way 05stang808 Visual 3 May 28th, 2007 08:59 PM
Removing the honeycomb Juggalo_X V6 Mustangs 24 May 3rd, 2007 12:00 PM
Removing air silencer ? Hudstang 96-98 4 April 20th, 2007 12:04 AM
Removing Air Bag ? 92lx5oh 5.0 Mustangs 3 April 10th, 2007 10:19 PM
i need help removing these YNOT 5.0 Mustangs 13 April 2nd, 2007 01:33 AM
