1967 mustang coupe
67 mustang engine swap need advice
just recently purchased a 67 mustang coupe with a 250 cid 6 cyl the car has had front brakes changed to disk off of an 80 granada also has 5 lug rearend out of a 68 mustang also came with a 5.0 fuel injected engine and automatic overdrive transmission out of a 90 model lincoln town car i am planning to put in car. my question is should i convert engine to carb or change car to efi what are the pros and cons of efi
what will i need for swap to carb, what will i need to swap car to efi your advice is appreciated thanks Jim Last edited by Atoka Jim; April 12th, 2009 at 11:20 PM. Reason: left something out |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Welcome to MM Forums,
The question is a good one. It depends on you, how mechanical you are. EFI is always the way to go, but if you dont know how to set it up then the carb is the easiest way to go. EFI swap all you need is the wiring and controller 'CPU' Painless has this and ford racing has it also. Carb set up you need intake, carb & MSD for dist. Good Luck |
1967 mustang coupe
i have friends that can help with the swap problem is some say carb some efi
i would rather have efi but have heard about a lot of problems getting everything right and i do not want to do something that going to cause prolonged problems i would rather do it right the first time that is the reason i am looking at the pros and cons each way thanks Jim |
Lost in the 60's
12.6 @ 114.3
EFI, you have to make sure all the sensors are good.
Most people dont worry about them and cry when it doesnt work. Just think the CPU can only set the setting to what the sensor are telling it. Painless wiring |
1967 mustang coupe
thanks for the info i will let you know how it comes together
Thanks, Jim |
Make sure you get the wiring harness from the EFI engine and all the sensors like MustangOne said. Very frustating to try and chase all the problems otherwise. There are several other forums that have a writeup on swapping just search the internet.
Threads Similar to: 67 mustang engine swap need advice
| Engine Swap in a 1967 Mustang | onetwin69 | All Other Vehicles | 1 | September 25th, 2007 05:45 PM |
| Possible engine swap for '00 Mustang? | drumming_guitarist06 | V6 Mustangs | 13 | August 15th, 2007 12:04 AM |
| MODULAR ENGINE SWAP IN A 1968 MUSTANG.... | BIGBUB1968 | Classic Mustangs | 9 | February 14th, 2007 09:55 PM |
| engine swap? i need some advice | cobrakid | 5.0 Mustangs | 7 | January 17th, 2007 07:52 PM |
| 99 to 02 Mustang GT engine swap? | damianojeda | 99-04 | 5 | August 22nd, 2006 08:23 AM |
