Charging System
Old June 3rd, 2009, 05:05 PM   #1
1994 Mustang SVT
fct/frm is on a distinguished road
Charging System
Ok last night i start up my new motor only to realize that the voltmeter is only reading 12volts. I have followed the wiring diagrams as completely as possible and all the parts are new. So i must have made an oops somewhere and i have a small idea where. In the wiring diagram the black voltage regulator wire and the GND wire of the alternator splice before going to ground, why is this and isnt a ground a ground(i did want to save some weight and wire so they have separate grounds)? Well so far as i know all the rest of the wires are correct, the white voltage regulator wire goes to STA at alt., the green reg. wire to run, the yellow reg. wire to solenoid and the BAT alt. wire to solenoid as well. I dont have the ammeter wired because i dont have one, but did put a voltmeter in instead, assuming the alt. does make 14volts. Any help explaining the whys, hows and what-nots would be great and much appreciated.
Old June 3rd, 2009, 05:18 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
Welcome To MM Forums...
The quik way to test it is the add power to the field post "orange" on the alt.
It is the post beside the battary post.
That will let you know if your alt is good
Threads Similar to: Charging System
charging system... FoxHoss 5.0 Mustangs 1 June 29th, 2008 06:29 PM
67 not charging 67mustangconvert Classic Mustangs 7 June 3rd, 2008 04:04 AM
need help with charging system asap 86ttops 5.0 Mustangs 7 March 30th, 2008 12:12 AM
charging help! pnyboi 5.0 Mustangs 3 May 7th, 2007 06:54 PM
UD Pulleys Rob Charging System? Finegan 2005 - 2010 4 April 17th, 2007 01:16 PM
