Water pump ???
Old January 28th, 2007, 09:42 PM   #1
Fastback GT's Avatar
Fastback GT is on a distinguished road
Water pump ???
I'm building a 393 stroker, it's a 74 block and I want to run a passenger side inlet water pump.
Has anyone run into this or know if using a timing cover for a passenger side inlet water pump will do the trick. I have heard that the water pump's are different lengths. which will mess up the belt alignment. I have seen this done but the guy did not know how it was done, he had bought it like that.........
Thanks Bill
My Lug Nuts Have More Torque Than Your Honda !!
Old January 29th, 2007, 07:16 AM   #2
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Don't had a clue, but could you goto the parts store and have them get both water pumps out and look at them side by side and tell?
Classic Mustangs are the best! Get one.
Old January 29th, 2007, 12:51 PM   #3
Grimmy is on a distinguished road
Send a message via Yahoo to Grimmy
That issue was talked about in a book i just bought, I will go back to that section tonight and let you know tomorrow.
Originally Posted by BWAL09
*gets down on knees*
grimmy, will you show me your cockle?
Official MM Zeppelineers. Crew member #1 - Captain
Old January 29th, 2007, 04:18 PM   #4
Thank you !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks Bill
Old January 29th, 2007, 05:49 PM   #5
no problem i just have to write myself a note. my memory is horrible.
Old January 29th, 2007, 08:36 PM   #6
All good !!!! The name of the book would work.?.
Thanks Bill
Old January 30th, 2007, 01:01 PM   #7
S#!t, I'm sorry. Im going to have to go back and look again. I was looking for the 302 not the 351.
let me tell you what I did read.
He typically lumps the engines together and doesn't give specifics to just one engine. The only clearance problem listed was if you have a dual roller timing set your oil slinger won't clear the chain. as for one water pump being larger than the other I don't believe so. the pics all looked to be the same height, but you know how pics are. I'm pretty sure he would have mentioned something if they were though, as he mentioned the 1994+ were considerably smaller pumps. You might have to buy a new harmonic balancer if you do this, I will double check that for you. But I do believe that the marks will not line up with the older cover.
the name of the book is How to Rebuild the Small-Block Ford:
From Tear-Down to Break-In written by George Reid.
http://www.themotorbookstore.com/reb...lock-ford.html
Old January 30th, 2007, 06:48 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Re: Water pump ???
I've done this on two different cars and never had a problem with length. I think the only difference is the inlet side. I am pretty sure all other dimensions are the same.
289-351W pumps are the same with the exception of the serpentine reverse rotation pumps.
Old January 30th, 2007, 07:44 PM   #9
Thanks !!!!! I'm going to line up some pumps and timing chain covers and see what I can.
Thanks Bill
Old January 30th, 2007, 07:46 PM   #10
Oh man. You couldn't have said that to him in a PM? Here I was feeling usefull around here, which doesn't happen often, and you had to go and take that away from me. I guess I'll just have to wait for another blue moon. lol.
Old January 31st, 2007, 04:48 PM   #11
No No No
That was for both of ya.
Thanks !!!!!!!!!!!!
Thanks Bill
Old January 31st, 2007, 05:49 PM   #12
Oh, I know I was just messing around.
I forgot to check on the harmonic balancer for you last night. I'll have to write myself another note.
btw why do you want to go with the left hand inlet waterpump.?
Old January 31st, 2007, 10:49 PM   #13
I'm running a 289 now and have the chrome hoses, afco aluminum radiator and a Gilmore belt drive for a standard rotation W Pump....
Thanks Bill
Old February 3rd, 2007, 05:33 PM   #14
you might need a new harmonic balancer then, if I recall correctly your 289 has a 28 oz counter weight and your 351 takes a 50 oz weight. I'll look it up and get back to you.
Old February 4th, 2007, 08:57 AM   #15
Rotating assembly has been balanced with a 28 oz dampener 4 bolt
Thanks Bill
Old February 24th, 2007, 03:37 PM   #16
latamud is on a distinguished road
50 oz was on 5.0 engines and started around 86.
You want a pre 70 style water pump to get the inlet on the passenger side and keep the normal rotation pulley. Get a pump for a 64-69 Mustang with a 289 and it will mate up to your 351w timing cover.
I did the opposite in my car, I went from a passenger inlet to a driver inlet pump so I could run an aluminum crossflow radiator. I bought a high flow Edelbrock Victor Jr pump for a 1970 Mustang. I recommend a high flow water pump for any engine, it will help keep your engine cool.
66 Coupe, Supercharged 408 Clevor, Viper T56, Cobra IRS
66 Coupe, Supercharged 03 Cobra drivetrain and suspension (project)
03 Viper, Supercharged
Threads Similar to: Water pump ???
Bad Water Pump? gotboost562 5.0 Mustangs 14 October 2nd, 2007 11:55 PM
Water pump 90Stang 5.0 Mustangs 13 July 8th, 2007 05:57 PM
water pump 95wip 94-95 6 May 23rd, 2007 10:03 AM
Water Pump cobralini V6 Mustangs 1 August 3rd, 2006 07:48 PM
water pump going? magnifistang 5.0 Mustangs 8 January 12th, 2006 10:49 PM
