Discussing Z bar adjustment in the Classic Mustangs Forum. Should the Z bar be tight between the block and frame rail, or should there ...
Old June 29th, 2009, 12:36 AM   #1
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
Z bar adjustment
Should the Z bar be tight between the block and frame rail, or should there be some play in it? When I installed mine, it put the bolts for the adjustment rod against the header, and I can't even press the pedal in, and it seems if I make it more loose, it will move it towards the frame rail a little, and clear the header. If it's like that, it seems like it will move around, and rub the header again though. M1, you have any tips on getting the setup right? anybody else?
When I took it out, I left the adjustment rod attached to the Z bar, so I didn't really change anything, and it seems like it should have gone right back in, but I was wrong.
Old June 29th, 2009, 08:36 AM   #2
June 08 ROTM
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
it should not be tight.
MustangOne's Car's
http://i231.photobucket.com/albums/ee205/StangRus/Logos/sig_mustang_one_large.gif
Old June 29th, 2009, 10:14 AM   #3
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
ok
Now I just have to figure out why it's rubbing the header now, but wasn't before.
Old June 29th, 2009, 11:19 AM   #4
460brevill's Avatar
did you change engine or tranny mounts?
i sixing 200 six with 300 hp.
Old June 29th, 2009, 11:27 AM   #5
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
Nope. I didn't even take the engine mounts off the block, and I didn't remove the tranny.
Old June 30th, 2009, 07:53 AM   #6
June 08 ROTM
MustangOne's Avatar
12.6 @ 114.3
Hmm, Maybe you have the motor in backwards...
You just have to love the little things that make the day so much fun...
MustangOne's Car's
Old June 30th, 2009, 09:48 AM   #7
69fastback's Avatar
1969 Mustang Mach 1
OLDNSLO
I got it figured out. I had it way too tight between the block and frame rail. The thing is a PITA to adjust, but with 2 extensions, and 2 wobble joints, you can do it without removing the header
Old June 30th, 2009, 08:04 PM   #8
460brevill's Avatar
hot dog!!!!!!!!!!!!!!
Threads Similar to: Z bar adjustment
Light Bar/Styling bar Cadillac Convertibles 10 February 17th, 2009 09:29 AM
Adjustment?? jonnotch 5.0 Mustangs 5 April 26th, 2008 10:11 PM
Timing Adjustment 89 LX... teal89 5.0 Mustangs 2 February 13th, 2008 02:34 AM
Clutch adjustment?? 06GTMustang89 2005 - 2009 12 February 9th, 2008 06:29 AM
E- Brake Adjustment? chris1 Modular Mustangs 1 May 28th, 2007 06:37 PM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
