LinkBack (1) | Thread Tools |
#1
What engines ccan a standard C4 handle without major modification?
because i want to put in a 302 engine block and am worried that i will break my tranny. so does anyone know? (its my first real engine swap, I'm replacing the straight 6 my 67 currently has for something with a little more oomph)
13.82@100.26
I know the foxes had a c4 behind the 302. And pulled fine.
thanx you woulndt happen to know if this 302 5.0L/302 - 340 HP GT-40 ALUMINUM HEAD FORD RACING PERFORMANCE CRATE ENGINE ASSEMBLY MISCFORD would fit in the standard bay for the 67 without issues would you?
1967 Mustang Coupe
It is a 302, should have no problem.
1967 Mustange Coupe, 200i
A 67 engine bay was designed to hold up to a 429 (not that changing spark plugs will be easy with an engine that big, but it will "fit")...A 302 should have not problem fitting.
a c4 will hold up fine. but if you plan to shift it yourself you might want to get a full manual valve body, tci makes some good ones case you need ideas.
what katen said.
i sixing 200 six with 300 hp. |
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
302's were standard an pretty much all 302's so yes. It's will handle it just fine unless you plan on making some massive #'s
The Curse's tranny bleeding like a stuck pig 600 CFM Edelbrock, Hookers, Pertronix dizzy, Accel coil, GT40 heads, 5.0 h.o,Super 44's, SSBC, FRPP 9mm wires
thanks guys now i just have to save for one or find a cheap one. do you guys know if you can rip a 302 from a newer model mustang (say 80's and later) and still have it work or am i just being stupid. (I already know i probly am i don't really know a whole lot about car mechanics i just enjoy drving them).
aint nothing but nuts and bolts.
oh also it's an automatic i totally zoned on that fact
LinkBack to this Thread: http://www.moddedmustangs.com/forums/classic-mustangs/129725-what-engines-ccan-standard-c4-handle-without-major-modification.html
| Mustang Restorations » What engines ccan a standard C4 handle without major modification? | This thread | Pingback | July 14th, 2009 08:54 PM | |
Threads Similar to: What engines ccan a standard C4 handle without major modification?
| Exhaust modification | KIKa55GT | 96-98 | 4 | January 16th, 2008 02:37 PM |
| iac gasket modification | laser_red_3.8 | V6 Mustangs | 13 | September 25th, 2007 12:29 AM |
| Would Either Of These Engines Fit With Little Modification? | energiesource | 99-04 | 4 | October 24th, 2006 11:02 AM |
| h pipe modification | militarygt | 5.0 Mustangs | 5 | July 31st, 2006 10:22 PM |
| I Need Help with Modification Ideas | missmichelle | V6 Mustangs | 7 | July 30th, 2006 11:44 PM |
