1968 & 1991 Mustangs
68 Mustang engine swap question
Hello everyone. I have a 68 mustang with a 78 302 in it now. I want to put an 88-93 Carb'd 5.0 motor in it. I have tried finding a "how to" on just putting a 5.0 into it 67-68 but havn't found quite what i'm looking for. On top of it I'm not sure which category the 78 parts on my engine now fit into. If someone could help me out I would greatly appreciate it. Thanks in advance.
anybody?
Priest of the Car Gods
If you're staying carb'd and already have a smallblock in there, I don't think you have to do anything special, just pull your old motor and drop the new one in. If you've got a 4-speed in your '68 currently, you might take the chance to upgrade to a 5-speed, and just have a custom driveshaft made for the T-5 (or whatever you choose to go with).
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
The 5.0 is the same bolt pattern on the block and heads as your 302.
Things that you will have to use off your old motor is the timing chain cover and water pump. You will need to buy a flywheel 50 oz 157 thoot to still use your transmission. |
thank you. i have the 78 c4 in it. fyi.
does anyone know why i have to change the timing cover and the waterpump
Lost in the 60's
12.6 @ 114.3
Yes, I do
If your motor is a 88-93 EFI it will not have the fuel pump opening on the timing chain cover. And the newer motors have the lower rad hose on the drivers side instead of the passagers side. Water pump is alot cheaper than a Radaitor. You can use the ones off your old motor, and pullys. You still will need to buy a flywheel 50 oz 157 thoot to still use your transmission. in 1982 &up the motors are 50oz and 164 flywheels.
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; July 19th, 2009 at 10:08 PM. |
i actually am going to purchase a new radiator i have the original one in the car and its really beat up and rusty. so from what you said if i buy a newer style radiator i can use the newer water pump. anyone correct me if i'm wrong. lol
Lost in the 60's
12.6 @ 114.3
you still need to buy a radaitor to fit your car. I would buy a 1968 24" big block radaitor.
It will fit your car and have the bottem rad hose on the drivers side. Just remember to buy the mounting brackets for the stock rad. If you go Griffin or Northern Radaitor you can make your own.
MustangOne's Car's![]() How to post Photos in Your Thread. Vote for your Favorite Ride of the month, Every Month Modded Mustangs Facebook Last edited by MustangOne; July 20th, 2009 at 08:12 AM. |
thank you for your help everyone.
Lost in the 60's
12.6 @ 114.3
Any time.
Good Luck |
Threads Similar to: 68 Mustang engine swap question
| Engine swap question | hopper | 5.0 Mustangs | 9 | November 7th, 2008 04:23 PM |
| Engine Swap Question! | 02MustangV6e9 | 5.0 Mustangs | 3 | September 24th, 2008 02:16 AM |
| Engine swap question | energiesource | 99-04 | 11 | September 19th, 2008 06:54 PM |
| Possible engine swap for '00 Mustang? | drumming_guitarist06 | V6 Mustangs | 13 | August 15th, 2007 12:04 AM |
| 99 to 02 Mustang GT engine swap? | damianojeda | 99-04 | 5 | August 22nd, 2006 08:23 AM |
