1969 Mustang Mach 1
7.324@94.61 N/A
wiped a cam lobe
Well, my new Comp Cams XE274H didn't make it very long. I've been having some problems with it every since I installed it, and after some time with them on the phone,and doing some different things, we're almost certain a lobe went down. I'm getting ready to go pull the intake and check it out.
![]() ProSystems Aeromotive TFS MSD Bullet Induction Solutions PA Moser |
another dahm ford
thats no good. are they gonna replace if it did go bad?
![]() 97' 3.8 to 4.6 swap all stock 67' mustang gt coupe 88' ranger, just a clean ass truck 48' jeep cj2 the work hogg |
1969 Mustang Mach 1
7.324@94.61 N/A
I hope so. I'm waiting on a call back from the warranty department, but from what I understand, they're usually pretty good about warrantying stuff like this. It sucks I'll have to tear it all back apart though, and it's still going to cost at least $100 in gaskets and fluids, not to mention my times.
1969 Mustang Mach 1
7.324@94.61 N/A
Good news. I just pulled it apart, and found a collapsed lifter. Maybe I'll be ok.
check the bottom of that lifter.if it is mushroomed.or has a hole in it ,you need to take a good look at the cam.
i sixing 200 six with 300 hp. |
1969 Mustang Mach 1
7.324@94.61 N/A
The bottom of the lifters look fine.
The warranty guy called and said if I replace the lifter with a new one, on a cam that already has some use on it, it probably will wipe the lobe : . It's amazing to me that a flat tappet cam is so fragile. I wish I would have just went with a roller one now . He did tell me, if I want to pull the cam and send it back, they would go ahead and send me a new cam and lifters, so that won't happen, but damn what a PITA.My other options are to take the chance with the new lifter, or check my lobes, and if they're ok take the lifter apart, and see if there's some trash in it, or a burr on the pluger, clean it up, and put it back in.
dont put that lifter back.i have seen a lot of lifters replaced single and do fine.just get a bottle of cam break in lube and chang oil and filter to start.might save a lot of trouble.
1969 Mustang Mach 1
7.324@94.61 N/A
Well, since they offered to replace everything, I just decided to do that. It's a PITA, but it would be crazy to not take them up on it, so I'm getting ready to go up and pull the cam again. I think it will come out without pulling the engine, so maybe it won't be too bad.
todays oils dont provide a good breakin,so add a bottle of cam breakin additive to it.good luck.
1969 Mustang Mach 1
7.324@94.61 N/A
Valvoline VR1 claims to have sufficient zinc levels for flat tappet cams, but I was still using the break in additive. I have the cam out, and it looks fine, so I guess it was just a lifter problem. They still want me to replace it all, and they're doing it under warranty, so I may as well do it.
1998 Mustang GT
1:34.43@13.86
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
#12 | |
66 Coupe.
It's good to hear the company will back there product to replacing it with no arguments. Very cool. |
1969 Mustang Mach 1
7.324@94.61 N/A
I actually checked it with a dial indicator, and it checked OK. I do have to say, I'm happy with the warranty department. I called asking for a lifter set, and they practically insisted on replacing all of it.
good deal.sign of a good company.good luck.
I am actually quite surprised cam companies are so quick to replace cams with wiped lobes. It is so common now, they have tio be losing their arses on warranty claims
1967 C code. 306- Performer RPM heads/intake, Quickfuel 680 and patriot headers. Backed by a t5z and a 3.55 peg leg out back for now
#16 | |
1969 Mustang Mach 1
7.324@94.61 N/A
I think forums like this have helped customer service, because if my new cam and lifters were ruined, I'd be plastrering it on every message board I knew of, if they weren't going to warranty it. Instead, I'm telling people they insisted in replacing it all. There are lots of companies making good products, but customer service is what makes or breaks compaines.
#17 | |
'95 GT
Was probably faster before I got it.
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it? ![]()
#18 | |
And yes unfortunately oil nowadays suck, low zddp in pretty much every oil. I would look at using Joe Gibbs "hot rod" oil. They claim it has very suffiecient amounts of zinc so it should be great for flat tappet cams. It is a bit pricey though but better than having to change the cam again.
Threads Similar to: wiped a cam lobe
| Worn Cam Lobe | scxc15 | 99-04 | 6 | March 4th, 2009 11:19 PM |
| Cam installation - Comp cam stage II | Dolbs4082 | 99-04 | 4 | February 28th, 2009 11:36 PM |
| For your reference- The sound of a wiped cam in a 460 | BigBlockFairlane | Videos | 3 | November 11th, 2007 09:58 AM |
| E cam or F cam horsepower and 1/4 mile time questions | GreyGhost | 5.0 Mustangs | 1 | August 21st, 2006 07:25 PM |
