wire problem....always hot!!!
I just installed my new engine. Set up the harness the same way i did last time. I have a 1 wire alternator, HEI distributor that has a constant 12v source running to it for the factory harness, I kept the same starter and hooked it up to the siloniod as well as a 10 gauge wire to ground the starter. I also put a 10g wire from the engine to the firewall to ground the engine. My problem is that the car is live(hot) always now. I try to hook the bat up and it just keeps sparking at the post? Can anyone help me with this. I want to hear my new motor!!! What did i do wrong?
2001 mustang gt 5 speed Full bolt ons with 4.10 gears. 1965 Mustang 302 with 4 Barrel edelbrock 600cfm, T5 transmission, Hurst short throw shifter. In the process of restoring it... |
ok fixed that on my own. had siloniod crossed. But now im trying to start and it will turn over but im not getting fuel. I have a new holley mechanical pump. Does it take alittle while to get the pump to pump the gas from the tank after having it sit for awhile?
#3 | |
66 Coupe.
Fuel, Spark on time and air is all it takes to fire it. So check for fuel shooting into the carb. first.. Then maybe the dizzy 1/2 turn off?? But usually if the Distributor is 1/2 off the engine will still bang and sputter along with back firing through the Carb. If you are not getting fuel to the carb, I would get something to hold a 1/4 of a cup or so of fuel, (NOT THE GAS CAN!!) and pour it down the carb, Put your air cleaner back on the Carb. before firing it, a backfire could destroy your wiring and other stuff up to the whole truck! If the engine runs but dies do it again, If it dies again, you have another problem. Fuel from the gas tank to the carb.. If that's the case, You'll have to find and open the obstruction. (If it's not the fuel pump) Carb. fuel filter plugged, floats in the Bowl set too low, Etc. Last edited by 66 STANGSTER; August 8th, 2009 at 10:46 PM. |
i pulled the braided fuel line of the hard line going to the tank to check the suction. I had someone crank the motor over while i stuck my thumb on the line from the pump and nothing. Didnt feel any suction? what yall think. Could the fuel pump lever be in the wrong postion. Do i to have the cam in a certain postion before i put the pump back it or what. I cant figure out why the new pump wont work unless the lever is sitting in wrong spot.
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
pull the pump and check to make sure that on the off chance you didn't get a bad pump. when you put it back make sure the eccentric is in the up position, and you should be good to.
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
found my problem. Guy who i bought the motor from built the motor for a electric fuel pump, not mechanical. didnt tell me this when i got it but oh well. Now im going to have to get a good electric fuel pump for it because im not going to disassemble the hole front of the motor again. This would be my 3rd time to do so. Does anyone know a good electric fuel pump to buy and from a site to get it at. I need it here by tuesday. I dont need anything to expensive. Just the pump, no regulator. I want something around 120-140 gph at 9psi or under.
#7 | |
66 Coupe.
As far as electric, Just hit Summit or Jegs for the Holley street version. It is self regulated for the street. |
#8 | |
Lost in the 60's
1968 GT 500 Super Snake
12.6 @ 114.3
Rod? ![]() ![]() Just to let you know the ford mechanical fuel pumps run off a fuel eccentric. It mounts on the front of the timing chain and the fuel pump arm ride under it.
chevy use a rod if im not mistaken not fords.
66 Coupe.
Yes, Thought about it in bed last night...
Sorry, You can tell what I've been working on the last few years..
haha it happens to the bust of us. For an elec pump I have had good luck with the summit branded pumps, cheap and work well. Fairly loud but so are most aftermarket fuel pumps. Gotta love the simplicity of a mech pump though, too bad your engine doesn't have the eccentric installed.
1967 C code. 306- Performer RPM heads/intake, Quickfuel 680 and patriot headers. Backed by a t5z and a 3.55 peg leg out back for now
Threads Similar to: wire problem....always hot!!!
| Hot chics, hot cars, cool water | homebrewed | The Clubhouse | 6 | July 20th, 2008 05:39 PM |
| hey need help with hard wire install (Hot in Run) | 94stang | Audio/Video | 6 | May 9th, 2008 11:34 AM |
| o2 wire problem | supercharged03gt | 99-04 | 1 | January 11th, 2008 08:16 PM |
| Key-On Hot wire | dStoltenberg | 5.0 Mustangs | 4 | October 10th, 2007 12:35 AM |
| fixed my hot no start problem, now i have a new issue!!!! | gixxer1 | 5.0 Mustangs | 2 | August 30th, 2006 09:16 PM |
