FMX to C6 linkage prob
Old February 9th, 2007, 11:25 AM   #1
aldrew is on a distinguished road
Hello everyone, I am new to this forum.
I have a 73 Mach I that I have almost completed a moderate refurbishment. Due to the excessive work on the motor (450 HP), so I swapped out the old FMX for a rebuilt C6 with a performance shift kit. However the linkage does not match up with the floor shifter.
Anyone have any suggestions on how I can fix this without buying an after market shifter (like a B&M)? I want to keep the stock floor shifter if I can.
Thanks
Old February 9th, 2007, 02:06 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
I don't know, but I swapped out my FMX for a C4 on my last 69, and it worked fine.
Good choice on ditching the FMX.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old February 10th, 2007, 02:13 AM   #3
73gt is on a distinguished road
check with Perogie enterprises I think they can hook u up with the right linkage.
Old February 11th, 2007, 11:27 AM   #4
OldSchool is on a distinguished road
On my 65 someone changed the tranny and the main problem was that the length of the shift lever on the tranny was to short so the shifter in the car never lined up with the numbers.
If that is what your prob is, changing the length of the linkage rods will not fix it. The only thing to do is to make sure the lever on the tranny is the same length as stock.
http://home.att.net/~lightingcontrols/mustang1.gif
Year One and Year Old
Old February 12th, 2007, 01:25 PM   #5
Oldschool - you are right. I checked the lever on my old FMX, which I still have and not only it longer, it has a 90 degree elbow.
I local Mustang place out here said I could swap out my floor shifter from another 71-73 Mach I that had a stock C6 in it. unfortunately, he did not have one, and neither did another local classic Mustang shop.
The next best thing I could do was fashion a bracket that I bolted on to the C6 lever to extend it and it seamed to work. The two line up pretty good. I will probably need to tinker with the length a little.
If I knew how, I would simply remove the lever from my FMX and put it on my C6, but they are not bolt on and it looks like you need to get into the tranny to do it.
I will keep looking for a floor shifter from a 71-73 that had a C6. I have been told it my best best is one with a big block in it, since that is what Ford was mating with a C6 tranny. The small blocks ie 351 had the FMX.
Thanks for the input.
Threads Similar to: FMX to C6 linkage prob
sniper prob!! WLJohnson05 V6 Mustangs 41 July 30th, 2007 01:16 AM
clutch prob? thatonekidw/theGT Modular Mustangs 12 July 18th, 2007 10:29 PM
So Basically I got a Prob. 97_4.6L_Stang 96-98 19 February 12th, 2007 02:59 AM
GTO T-56 linkage banini Modular Mustangs 5 September 15th, 2006 09:09 PM
tech prob robert178 5.0 Mustangs 1 August 18th, 2006 10:08 AM
