Disk brake donor cars - Page 2
Old September 27th, 2009, 11:33 AM   #21
chris66dad's Avatar
chris66dad is on a distinguished road
I bought the kit for the 66 from CSRP and it was a simple install with great directions for step by step guidance. A GREAT BARGAIN AT $524. EVERYTHING you will need in 1 box, And EVERYTHING is NEW.
You will not be able to beat the price by using used parts from donor cars. Figure you will be buying worn out parts that will need to be rebuilt or replaced. Then add in what you think your time and gas money is worth running around to Pick and Pull.
I went to a local junkyard and they told me $250 for the for the Granada spindles, calipers and discs. They would pull the parts though.
Then figure I would need to rebuild, resurface and install new bearings. Oh and dont forget about the MASTER CYLINDER AND PROPORTIONING VALVE.
Below from someone who did it Disc Brake Swap
Source Part Number Qty Description Unit Price Total
Western Auto S13 2 77 Grenada inner wheel bearings $5.99 $11.98
AutoZone 693226 2 77 Grenada outer wheel bearings $6.97 $13.94
Western Auto 71-19221 2 77 Grenada Wheel Seals $1.89 $3.78
Salvage yard N/A 2 77 Grenada Spindles (with backing plates and calipers for core charge) $30.00 $60.00
AutoZone 561720 2 77 Grenada brake rotors $39.99 $79.98
Western Auto 18-4069/18-4070 2 77 Grenada brake calipers $13.99 $27.98
Western Auto BH36649 2 77 Grenada brake hoses $18.99 $37.98
Western Auto RR-D91 1 77 Grenada brake pads $12.99 $12.99
Plaza Auto Parts 258340 2 Brake hose adapters $1.82 $3.64
Toms Auto Parts H5527 2 77 Grenada caliper hardwares $11.04 $22.08
Master Power Brakes 1 Dual reservoir master cylinder $69.95 $69.95
Master Power Brakes 1350K 1 Proportioning valve $129.95 $129.95
Mustangs Unlimited C5ZZ3590ARS 01 1 Idler arm and Pitman arm (GT-350 kit) $119.95 $119.95
Dallas Mustang 1431 1 Center (drag) link $96.28 $96.28
AutoZone SL77 1 Stabilizer end link kit $6.94 $6.94
AutoZone 2 77 Grenada outer tie rod ends $31.00 $62.00
Salvage yard N/A 2 5 lug rims (14 inch) $10.00 $20.00
TOTAL COST $779.42
Here are pictures and info on our disc install from our install on The 66 from our website:
Front Disk Brakes
Good Luck and BE Safe
Ron
Christophers 66 Mustang Restoration and Modification
http://chris66dad.tripod.com/
Father Son Restoration
A code 66 coupe
289 4v, Roller Rockers, Electric fan
Performer & 650 Edelbrock
MSD ignition
Tri Y into 2.25 Shelby side exhaust
T5 conversion and 3.55 Trac Lok
Hydraulic clutch
CSRP Discs
Last edited by chris66dad; September 27th, 2009 at 11:37 AM. Reason: tried to get part list to column but no go...
Threads Similar to: Disk brake donor cars
Would this be an OK donor car? Kuro The Clubhouse 15 July 15th, 2009 10:42 AM
Rear 4 lug disk brake swap questions. ajb4507 5.0 Mustangs 14 November 20th, 2008 10:37 PM
Donor Cars HBK_2007 Modular Mustangs 23 April 14th, 2008 01:29 PM
Wrecked/Donor Cars supermachone V6 Mustangs 4 January 5th, 2008 09:46 AM
5 lug 4 wheel disk brake conversion etony89 5.0 Mustangs 3 July 21st, 2007 10:48 PM
