289 distributor problems?
I removed my distrib and now I can get her to start can someone explainhow to set up timing in a very easy way I know most of it but I'm missing something Thanks Jeff
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
make sure your #1 piston is TDC on the compression stroke, have the rotor land on the #1 post when you put the dizzy in. if for some reason you cant get the dizzy to seat turn the shaft on the oil pump till it seats. make sure your points are propperly gapped and you should be good with some minor tuning.... someone correct me if i'm wrong...
The Curse's tranny bleeding like a stuck pig 600 CFM Edelbrock, Hookers, Pertronix dizzy, Accel coil, GT40 heads, 5.0 h.o,Super 44's, SSBC, FRPP 9mm wires
sounds good to me.
i sixing 200 six with 300 hp. |
289 dist
Thanks for the reply. This is what I have done so far. I have found TDC and placed the balancer at 0. However I can't seem to get the distributor/rotor to line up with the #1 cly . I placed a mark on the dist at #1 wire and a mark on the dist itself. the two just dont jive and all 3 just dont line up rotor/mark on #1 wire and #1cly. I do have spark at the coil, I just took a wire off the dist to see if I had spark and I did not see any. But Im still out of time correct? Thanks for all the help Jeff In Indy
2008 GTI
14.65 @ 99.83
you cant get the dizzy to seat?
Threads Similar to: 289 distributor problems?
| Do i have to get a different distributor? | fateisajester | 5.0 Mustangs | 5 | December 21st, 2008 04:01 AM |
| which steel distributor gear for my msd distributor? | STREET6 | 5.0 Mustangs | 0 | February 3rd, 2008 05:56 PM |
| New distributor? | GatoStang | All Other Vehicles | 1 | June 2nd, 2007 05:07 PM |
| Distributor ?? | jonnotch | 5.0 Mustangs | 7 | June 2nd, 2007 03:50 PM |
| Distributor? | jpretrack38 | 5.0 Mustangs | 3 | August 19th, 2006 12:02 AM |
