Discussing 3-Speed Automatic Tranny Issue in the Classic Mustangs Forum. I have a 1966, 302, 3-speed automatic. While the car runs good, I am ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
3-Speed Automatic Tranny IssueIt seems to shift into reverse pretty hard. It's apparently not the universal joint, since I recently had it replaced. And the idle seems about right. Does anybody else have this problem or any thoughts on what's going on with the drive train? |
It could be just a loose band in your trans. my 70 did that and then it wouldn'g go into reverse any more. I took it to the shop and it was a cheap fix
Classic Moderator
It could still be the U-joint. Maybe it was not put in right. Or how about the rearend? Crawl up under it and grab the driveshaft and turn it back and forth. If its not tight, then find out where its not tight at.
Classic Mustangs are the best! Get one. |
Exactly, it could still be the U joint or the bands. I’ll try to check the drive shaft myself today. But I have a body kit that runs along the side of the car close to the ground, so it might be hard to reach in under there and turn the drive shaft.
Actually, I made an appointment to have a tranny shop check it out this morning at no cost. I told him what the problem was over the phone, and he thought it might be the “vacuum modulator,” an easy fix.... I should hopefully know more in 24 hours . |
Well, I got an interesting response from the technician. He said "going hard into reverse is the nature of the beast -- the car runs good." He said he adjusted the band for reverse, but it wasn't much of an adjustment because it was almost right on anyway, so it won't really change anything.
It still bothers me; it doesn't seem right.... Any more suggestions? |
Classic Moderator
Get a T-5 five speed
#7 | |
try some Lucas transmission slip fix. just add it to the tranny fluid and it may fix your problem, if not, its probably serious enough to bother taking it to the shop
TO: Ricers- 1) there's no replacement for displacement 2) my lug nuts require more torque than your engine makes 3) a light car doesn't excuse a weak engine 4) a bottle of pepsi has more liters than your car eating rice builds muscle |
#9 | |
I've taken my car to three different tranny shops. One shop said it was "normal," another wanted to try a couple of pretty expensive fixes with no guarantee either one would work, and the other said the driveshaft slack seemed normal and that it sounded like something in the tranny itself. He made a couple of untoward comments about Mustangs, so I didn't follow up with him. I'll look around for other shops and get other opinions. |
#10 | ||
Re: 3-Speed Automatic Tranny Issue
Official MM Zeppelineers. Crew member #1 - Captain http://i170.photobucket.com/albums/u...m134137df1.jpg |
I am just gelious some of you can take yours out. It sucks living is snow and salt land
http://memimage.cardomain.net/member...619_7_full.jpg You know its all about the gurth these days... |
#12 | ||
I did buy some Lucas Transmission Slip, but haven't had a chance to use it yet. I'd be good if that fixed it. As for being able to drive our Mustangs this time of year, I do feel fortunate, considering I'm originally from the northeast. It'd be hard to enjoy your car back there this time of year. But in the spring, there's no place like the northeast. |
#13 | |
No, i don't think it's something to be fixed. I think that's normal.
#14 | |
#15 | ||
Classic Moderator
Yours is an auto so that makes it harder. You can get a T-5 from a junkyard and get a kit for about $300 to $400. I think you will need to have your driveshaft cut. I think that runs under $200. I would say that if you do it yourself, it would cost under $1500. |
#16 | |||
I have heard that not all T-5s are created equal. Some from the early 90s Mustangs deliver more torque. Have you heard that? So, it looks like I'd have to go with a new one, which I priced on Saturday -- $1,300. I wouldn't be able to do it myself. Too complicated for me, and I don’t have enough spare time, nor do I have the tools. But I am wondering about how the T-5 would work out in my car. Does it shift somewhat like the tyrannies in the new Mustang GT.? I drove one on Saturday and a 2006 Saleen. So, I know how those cars shift. Of, course I wouldn’t expect my 302 to perform like those cars. If I'd be okay with the way a T-shifts, I'd be willing to pursue a conversion kit with a professional installation in the near future. |
Classic Moderator
I got mine new in 1992 or some where around there. My T-5 is a heavy duty world class T-5 that would of went in Mustang GT or a t-bird SC. It works out very well. If you have the money, I would do it. You will have to change the rearend gears. I would go with the 3.55s or the 3.73s.
btw, my 67 c4 3sp auto does the same thing, lurches into reverse, im starting to believe its kinda normal for them, as this tranny was just rebuilt, or maybe its just not broken in yet, i have about 15 miles on it since rebuild so probably it hahaha
#19 | |
It seems like the higher the torque capacity the better. Is it true? |
Classic Moderator
Yep. If you are going to get a 300 horse 289, I would get the Super Duty, but anything more and I would get the Extra Heavy Duty one. Also if you are going to run slicks I would get the 600ft/lbs torque one.
Threads Similar to: 3-Speed Automatic Tranny Issue
| No tranny issue... Fuel filter maybe? ::Urgent help Needed:: | Hourofpain | V6 Mustangs | 2 | August 15th, 2007 01:18 PM |
| tranny/differential issue? | Murderjetz | V6 Mustangs | 11 | August 11th, 2007 01:10 AM |
| auto Tranny vibration-shifting issue | travster07 | Drivetrain | 2 | November 7th, 2006 12:21 AM |
| automatic tranny shifting too late? | 2007gt | Drivetrain | 1 | August 24th, 2006 03:46 AM |
| automatic or 5 speed | toygt4.6 | 99-04 | 5 | April 2nd, 2006 04:18 PM |
