Opinions needed! First Performance Mods
Old October 25th, 2009, 12:46 AM   #1
Mustang73Mach1's Avatar
1973 Mustang Mach 1
Mustang73Mach1 is on a distinguished road
Hello all, I have a '73 Q-code Mach 1 that I'm looking to get some more power out of. So far, I've put in a complete new suspension and a high-flow oil pump to get that 351C some decent oil flow, and now I'm looking to start improving its performance.
Here are some of the things I've considered, but I don't have the money to do it all at once:
-new headers & exhaust, leaning towards x-pipe
-more radical cam
-MSD ignition
-cylinder head swap... I've heard good things about the Aussie aka "3V" heads as opposed to my 4V
-or the biggest change, stroking the 351C to a 408.
Does anyone have any recommendations for what to do first? It doesn't have to be something on my list... I wouldn't want to blow the engine with something it couldn't handle yet. I've also been having trouble tracking down parts to fit a '73... and more specifically the 351C
Old October 25th, 2009, 12:05 PM   #2
Lost in the 60's
MustangOne's Avatar
1968 GT 500 Super Snake
12.6 @ 114.3
MustangOne has a spectacular aura aboutMustangOne has a spectacular aura aboutMustangOne has a spectacular aura about
I would go with E. All of the above.
here is the stroker kit.
here are 2 cams to look at.
COMP CamsŪ - Cam Details
Old October 25th, 2009, 06:40 PM   #3
1973 Mustang Mach 1
Yeah... all of the above would be ideal. I'm sure eventually I'll get it all, but I'll probably have to do it in 2 parts. Would I be safe doing the stroker kit and cam, and then the rest separately?
Thanks for the advice, and I appreciate the links!
Old October 26th, 2009, 03:10 PM   #4
Countryboy_99's Avatar
'95 GT
Was probably faster before I got it.
Countryboy_99 is on a distinguished road
I vote Ignition and Exhaust first. If you go with the stroker and cam kits your current exhaust and Ignition will just keep your reworked engine from realizing it's potential. Plus I think that would be the cheaper way to go.
Its red, long, and comes with an 8 foot bed attached. Wanna come play with it?
Old October 26th, 2009, 06:50 PM   #5
1973 Mustang Mach 1
Yeah, it's definitely cheaper. That's probably what I'll end up doing, then getting the stroker and cam a bit later. Thanks!!!
Old October 28th, 2009, 02:33 AM   #6
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice69fastback is just really nice
Gears
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old October 29th, 2009, 11:50 PM   #7
1973 Mustang Mach 1
Gears... there's something I hadn't really thought of. Nor do I know much about them unfortunately. What size would you recommend?
Old October 30th, 2009, 12:34 AM   #8
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
You'll get at least as much gain from gears as doing a cam swap, depending on what it has in it. Do you know what it has? Is the car a DD? What do you do with the car? Usually, a 3.73 is a good all around gear. I have 3.55s in mine and like them, becasue I drive it a lot.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old October 30th, 2009, 01:42 AM   #9
1973 Mustang Mach 1
I have another car for daily driving, so that isn't too much of an issue. I'll be happy as long as it's still streetable with a small amount of stop & go traffic.
Right now, I'm just casually driving it around, but I'd like to take it to some track days and open it up once I get all the kinks worked out and a few performance parts in it. This is my first real chance to put some bigger upgrades in, not counting the suspension.
It still has the stock gears, which I think are 3.25s. It seems like a lot of people go with 3.73s, at least that's what I see the most often. Do you think those would be best?
Thanks a lot for the advice too
Old October 30th, 2009, 12:17 PM   #10
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
In another car I had, I went from the stock 2.75s (which is what's in most 351/auto cars), to 3.73s and it was like I had done an engine swap. I think that's your best first mod because it's fairly cheap, and if you put a cam in it, generally it bumps the power range up a little bit and tall gears will KILL you.
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old October 30th, 2009, 12:38 PM   #11
1973 Mustang Mach 1
Sounds good. I did a little bit of research myself on gears and it sounds like gears are going to go to the top of my list! I'll probably do that, ignition, headers & exhaust first and the rest later.
Old October 30th, 2009, 12:54 PM   #12
69fastback's Avatar
1969 Mustang Mach 1
7.324@94.61 N/A
Sounds like a good start
ProSystems
Aeromotive
TFS
MSD
Bullet
Induction Solutions
PA
Moser
Old October 30th, 2009, 04:20 PM   #13
460brevill's Avatar
460brevill will become famous soon enough460brevill will become famous soon enough
mustangone will never steer you wrong.
i sixing 200 six with 300 hp.
Old October 31st, 2009, 09:35 AM   #14
Spiderz's Avatar
1965 Coupe, 351w
Spiderz is on a distinguished road
Send a message via AIM to Spiderz Send a message via MSN to Spiderz Send a message via Yahoo to Spiderz
I would do gears, Then get more air and fuel into the engine, more air out, then a rebuild.
Threads Similar to: Opinions needed! First Performance Mods
SO i need help with mods, opinions needed. VerumLIKE 2005 - 2010 23 April 1st, 2009 03:34 AM
Opinions Needed AnimalCrackers 2005 - 2010 42 March 27th, 2008 01:48 AM
Opinions needed 2006GTARPD3 2005 - 2010 42 March 6th, 2008 09:47 AM
opinions needed mikedoogen 2005 - 2010 1 July 31st, 2007 07:23 AM
Opinions needed?? acehogg69 The Clubhouse 10 July 30th, 2007 01:45 PM
